Go Back   The Supercar Registry > General Discussion > AMC
Old 09-24-2025, 10:21 AM
dykstra's Avatar
dykstra dykstra is offline
Congrats on the feature!!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
LetsFNgo (09-24-2025)
  #92
Old 09-26-2025, 04:55 AM
daverd daverd is offline
That’s great news love the AMC
2017 impala (wife’s car)
The Following User Says Thank You to daverd For This Useful Post:
LetsFNgo (09-26-2025)
  #93
Old 11-17-2025, 01:06 PM
LetsFNgo's Avatar
LetsFNgo LetsFNgo is offline
Probable last post on the SC360 for 2025.
Car is put away in the garage for the winter.
Beginning to order parts to make it nicer in 2026.
The rear suspension badly needs a rebuild. The left rear leaf spring has basically given up and sits 1.5” lower than the right side. Along with the springs the shackles will get rebushed and cleaned/painted.
Both doors need complete rebuilds with all rubbers and hinges. Along with replacing the carpet and finally installing a shifter boot so hot air isn’t constantly blowing on me when driving. I put some miles on the car this summer and that got old fast. Though it didn’t stop me from driving it.
The stroker engine is coming along, unfortunately I ran into issues with my crank machinist and had to repossess my crank from him last week. Hopefully by next week it’ll be in the mail to Michigan to be cut by a guy who’s done this job before, and for cheaper than what my local guy was going to charge me.
Marty loves this car, and I really want to work on it to make it safer and more reliable so we can take a ton of road trips in this as he gets older.
Probably not in 2026, but in 2027 I’d also like to do bodywork and repaint it in its original C1 Golden Lime Metallic. I’ve seen AMX’s done in this color, and it’s stunning when done right.
Thanks for reading. Will update when stroker 360 stuff happens. But otherwise the car is tucked away for now.
AMC weirdo
1969 SC/Rambler
1971 SC360 Hornet
1968 Rambler Gasser-under construction
1970 A66 Challenger- now 440+6
The Following 8 Users Say Thank You to LetsFNgo For This Useful Post:
dykstra (11-17-2025), Hawkeye (11-17-2025), L78_Nova (11-20-2025), markinnaples (11-20-2025), olredalert (11-17-2025), PeteLeathersac (01-31-2026), RPOLS3 (12-08-2025), Tenney (11-18-2025)
  #94
Old 01-31-2026, 01:01 PM
LetsFNgo's Avatar
I can post the smallest of updates on the SC360.
Tons of parts are ordered:
New leaf springs(120 day out back in November. Expected shipping date is March.)
All the parts to rebuild the rear suspension.
All the parts to rebuild and reseal the doors and trunk.
Carpet and shifter boot.
Parking brake cables so that’ll work.
A bunch of other small stuff that’s all shipping when the leaf springs ship.
The 360(now stroker) crank is out at the machine shop in Michigan. He started cutting it Thursday because he called with a few questions. He should have it cut sometime next week. Picture is of the box leaving to go there via UPS. Within a week or so I should be able to order the custom pistons to make this whole thing work. I have most of the other engine parts sitting in my basement. They include:
Rollmaster timing set
Crower Hydraulic Hauler cam
Johnson lifters
All of the other valvetrain parts
I did the interview for the Hemmings feature. It’s being written now for a planned release in March-ish.
Plans for 2026 involve driving the car to South Bend Indiana for AMO 2026. I’m planning a route that will be mostly scenic byways and small roads where I can stop for any shiny object(otherwise known as abandoned buildings) I see. It’s about 700 miles and I’m planning for a 2-3 day drive and camping in some national/state parks along the way. It’s basically a test run for when Marty gets a little older and we can do it together in this car.
Otherwise at -1 degree currently I’m not doing anything to the car. I pulled the battery out yesterday to make sure it doesn’t freeze. We’ve had a streak of mild winters so I didn’t worry when I parked the car. But I worry now with this long streak of cold weather we’re getting.
AMC weirdo
1969 SC/Rambler
1971 SC360 Hornet
The Following 7 Users Say Thank You to LetsFNgo For This Useful Post:
dykstra (01-31-2026), gtomike1967 (01-31-2026), L78_Nova (02-08-2026), markinnaples (02-02-2026), olredalert (01-31-2026), PeteLeathersac (01-31-2026), Tenney (02-01-2026)
  #95
Old 02-14-2026, 08:58 PM
LetsFNgo's Avatar
Decent update today.
The phrase “The shoemakers children never have shoes.” Comes to mind. I had some free time this afternoon and after getting the rear of the car up on stands I figured I’d start pulling the rear apart. I set up some cardboard, my dad built a fire in our small burn barrel, and I got to work disassembling the rear suspension to rebuild it for this year.
What I found was actually pretty terrifying. I drove this car ALOT last year, and quite a few of those were with passengers. I knew the drivers side leaf spring was worn out. So I wasn’t too surprised to find a broken centering pin bolt on the left side. What I was horrified to find was the right side literally fell apart while removing the spring plate/traction bar. The main leaf on the right side was broken, and from the wear, has been for a very long time. Which also explains the hose clamp on the leaf spring on the right side. It was keeping the spring together.
Getting past that I pulled the rear out, removed the leaf spring shackles and mounts, installed rear axle bump stops that were missing in the car. Luckily they’re the same as a Rambler and I have an extra set laying around.
I put a bunch of parts in the back of my daily VW to bring to work and clean on my breaks and lunches. I need to pick up a couple cans of spray paint and primer and next nice day I need to pressure wash the rear. I also found one of the new axle seals is leaking, Lucky me.
All in all it was good. Spent a couple hours outside and now when all the parts start rolling in I can get to rebuilding it all. Big plans for the car this summer. After seeing all this I might do the front suspension before I leave for South Bend.
Thanks for reading.
AMC weirdo
1969 SC/Rambler
1971 SC360 Hornet
big gear head (02-15-2026), Dave Rifkin (02-15-2026), dykstra (02-14-2026), L78_Nova (02-17-2026), L_e_e (02-15-2026), PeteLeathersac (02-14-2026), scuncio (02-14-2026), Tenney (02-15-2026)
  #96
Old 03-02-2026, 10:27 PM
LetsFNgo's Avatar
Small update today:
Spent some time restoring the Lakewood bars, 1 is complete, the other is blasted and will be finished by the end of the week. I’m waiting for a ton of parts to show up, including the leaf springs. I’m hopeful I can start putting the rear suspension back together next week.
Today I started the engine work. I’m working in kind of a tight area at the rear of my old dirt floor garage, but today I got the vertex magneto installed, installed new plugs gapped at .025, and installed plug wires but didn’t put them into the cap yet. I’ll wait for the wire separators to show up tomorrow and get everything sitting nicely before I cut and install everything.
If you read this and look at the included pictures, I understand this is stupid, especially on something I plan to street drive a lot, but I have the “correct” Dominators for this intake. Technically they’re Individual Runner 4500’s, the only model ever built for that. Ford used them on the Boss 302 trans am cars, AMC used them on the Javelin Trans Am car, Chrysler used them on IR Hemi’s. And several sets were used on Cleveland powered Panteras. Basically they’re supposed to be used like Webers. I’m going to try them on this. And if they absolutely suck to drive I’ll either switch to another set of Holleys or back to the Edelbrocks I don’t really like.
They may suck to drive. But they sure look impressive, and I’m hoping I can get them to work ok on this engine so I can use them on the stroker 360 when it’s done.
Should have another update around the end of the week or sometime next week. Also the Hemmings article is written and should be released in the next few weeks.
Thanks for reading.
AMC weirdo
1969 SC/Rambler
1971 SC360 Hornet
The Following 11 Users Say Thank You to LetsFNgo For This Useful Post:
big gear head (03-03-2026), Bill Pritchard (03-11-2026), cheveslakr (03-03-2026), Dave Rifkin (03-03-2026), dykstra (03-06-2026), gtomike1967 (03-02-2026), L78_Nova (03-03-2026), Lynn (03-02-2026), PeteLeathersac (03-03-2026), Tenney (03-03-2026), Too Many Projects (03-02-2026)
  #97
Old 03-06-2026, 07:01 PM
LetsFNgo's Avatar
Another updated today.
The second traction bar is all done, now just waiting on a small mountain of parts to come from Kennedy American so I can start putting the rear end of the car back together. Hopefully it all ships next week. We’re at 120 days of a 120 day back order. So any day hopefully the leaf springs will be shipping.
Spent some time today outside messing with the car in the garage. All the spark plug wires are run to the mag. Now I just have to run the switched ground wire inside the car so I can shut it off.
Most of the day was spent on the Dominators. Getting 2 sideways Holleys to do what you want them to do in unison without binding or hitting other stuff is not the easiest thing. But I made good progress after taking my time and figuring out how to get the carb linkages to clear. Unfortunately the pivot on the manifold binds so it needs to move forward about an inch. I’ll measure it tomorrow and work on it next week. If the weather is nice tomorrow I’ll pull the rear outside and get it pressure washed so next week I can get it painted and ready to put back in the car.
I also got the fuel lines run, but need to make a small bracket next week to support the Y. Not a big deal.
108 day until I pull out of the driveway in this thing heading to South Bend. A lot to do before that.
Thanks for reading.
AMC weirdo
1969 SC/Rambler
1971 SC360 Hornet
big gear head (03-07-2026), Dave Rifkin (03-09-2026), dykstra (03-06-2026), L78_Nova (03-08-2026), markinnaples (03-08-2026), PeteLeathersac (03-07-2026), Tenney (03-07-2026)
  #98
Old 03-10-2026, 01:53 PM
Nice:
https://www.hemmings.com/stories/thi...y%20Newsletter
The Following 6 Users Say Thank You to Lynn For This Useful Post:
Bill Pritchard (03-11-2026), cheveslakr (03-11-2026), dykstra (03-10-2026), L78_Nova (03-10-2026), LetsFNgo (03-10-2026), Tenney (03-11-2026)
  #99
Old 03-10-2026, 09:34 PM
Too Many Projects's Avatar
Really cool reading the story and I don't recall ever hearing about the plane ride to FL for the tunnel ram. And many of my friends think I'M nuts for the distances I go to for parts/cars. Fly to FL and never leave the airport is a new level of obsession...
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
  #100
Old 03-10-2026, 09:41 PM
I drove from OKC to a race track in Ohio to pick up a complete water buffalo hide interior for my 83 BMW 745i.
The Following 2 Users Say Thank You to Lynn For This Useful Post:
dykstra (03-10-2026), LetsFNgo (03-10-2026)
