Register | Album Gallery | Thread Gallery | FAQ | Members List | Calendar | Become a Paid Member | Search | Today's Posts | Mark Forums Read |
#261
68 Camaro...
Nice job on getting the front end pieces cleaned...looks great.
?? How does that Mark Ten unit work, I have seen these before, but not really up to speed on how they work. -wilma
02 Berger 380hp #95 Lots of L78 Novas Join National Nostalgic Nova! 70 Orange Cooler 69 Camaro |
The Following User Says Thank You to WILMASBOYL78 For This Useful Post: | ||
napa68 (11-25-2022) |
#263
Tim |
The Following 3 Users Say Thank You to napa68 For This Useful Post: | ||
#264
Looks great Tim!!
Dave Dykstra 1968 Camaro Palomino Ivory/Ivy Gold interior -Delivered to Courtesy Chevrolet, Los Angeles, CA 2013 Corvette Grand Sport 60th Anniversary -Delivered to Bill Jacobs Chevrolet, Joliet, IL NCRS#66003 “Education is what you get when you read the fine print. Experience is what you get if you don’t.”-Pete Seeger Dykstra Motorsports |
#265
Off to see the wizard tomorrow
The Following 13 Users Say Thank You to napa68 For This Useful Post: | ||
1967Z28 (12-12-2022), 427 (01-04-2023), 69M22Z (12-13-2022), big gear head (12-13-2022), cook_dw (12-16-2022), Crush (12-12-2022), dykstra (12-12-2022), John (12-20-2022), juliosz (12-12-2022), L78M22Rag (12-16-2022), olredalert (12-12-2022), PeteLeathersac (12-13-2022), Too Many Projects (12-12-2022) |
#266
Awesome!! Can’t wait to hear the bad assery!!!!
The Following User Says Thank You to dykstra For This Useful Post: | ||
napa68 (12-12-2022) |
#267
I see you have your snow shovel with....just in case...
Next 3 days down here will be interesting for weather.
Mitch 1970 Chevelle SS 1966 Chevelle SS 1967 Camaro ss/rs 1938 Business coupe, street rod 2000 FXSTS, original owner, 13k miles |
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
#269
The L88 is apart and all has held up well. The block, cylinder bores, pistons (TRW 12.5:1), crank journals all look good as does the dimple rods (bushed for floating pins). The ZL1 cam and lifters all look good, measured out to spec, and will be reused.
The only issue that was discovered is the flywheel was way out of balance (for whatever reason). That will get addressed and balanced with the pressure plate. I did notice there was a vibration above 5000 rpm. While it wasn't terrible, I felt it should be better. Glad we found a smoking gun there. So, a simple hone job and hot tank. All new rings, bearings, and gaskets. We'll add the 842 aluminum heads I had redone earlier this year (for this little side project) in addition to another 163 intake (divider milled out). Eric Jackson helped me source an old school Holley 4781 850DP. He should have that tomorrow to build a trick little carb specifically for this combination. I suspect by the end of January it should be on the dyno. Merry Christmas everyone! |
The Following 8 Users Say Thank You to napa68 For This Useful Post: | ||
1967Z28 (12-22-2022), 69M22Z (12-22-2022), big gear head (12-22-2022), dykstra (12-22-2022), juliosz (12-22-2022), olredalert (12-22-2022), RPOLS3 (12-24-2022), Steve Shauger (12-22-2022) |
#270
Great to hear Tim!!
Thread Tools | |
Display Modes | |
