Freeze plug problems
I noticed I had a coolant leak under my ss396 Camaro that I just had at MCACN in November. I didn't rebuild the engine because it only had 41k on the rebuild. I did change all the freeze plugs because I had one leaking. I used the green coolant 50/50 mix with tap water. I've probably only driven the car 3-400 miles since the restoration. I now have three freeze plugs leaking. The one pictured is one I just removed. These were brand new less than a year ago. The battery is never left connected when in the garage.
I sent this picture to my friend Larry (lbnaz) & he indicates that it's most likely a ground problem causing electrolysis. I guess I need to check my grounds but I wanted to ask if anybody has seen this & maybe, where was the problem found? Thank you, Joe
1968 Z/28 Corvette Bronze. Black Hounds Tooth. 02E Los Angeles born 3/13/1968 pnt OO 1969 SS396 Yellow/Yellow 08E Norwood born 8/28/1969 pnt 76E 1970 'cuda Moulin Rouge, 440-6, 4 speed |
I always use distilled water when I mix with new green anti-freeze. Too much crud in the tap water here. Maybe the stuff in the tap water is reacting?
The Following User Says Thank You to RPOLS3 For This Useful Post: | ||
X66 714 (09-15-2022) |
It never has before but once I resolve the problem I'll change everything out. I will have the old stuff tested that I pulled out....thank, Joe
Possibly, the freeze plugs have become a sacrificial anode. Brass or stainless-steel plugs may solve the problem.
https://www.corrosionpedia.com/defin...rificial-anode
Learning more and more about less and less... |
The Following User Says Thank You to William For This Useful Post: | ||
Seems like all my engines have brass freeze plugs …
Normally that's what I do except I was going for as close to original as possible. Do you know how hard it is to find 1-3/4 steel freeze plugs without writing all over them? Not fun....Joe
I just dropped off a coolant sample to Caterpillar. They will send it to a lab & I should get results back next week. 20 bucks (cheap) for lab work but I can't lose that engine. i'll keep checking for ground issues....Joe
The Following User Says Thank You to X66 714 For This Useful Post: | ||
Xplantdad (09-16-2022) |
----All my marine engines have brass freeze plugs, even if the boats are in fresh water. My incoming water is super purified (even de-ionized) before it goes anywhere in the house or garage, so no problem there!.....Bill S
Your coolant that is now in the engine will need to be fully flushed out , it is probably highly out of the PH range. Does your shifter cable seem to hard to move? If it is a bad ground it will try to use it as an alternative.
1971 Boss 351 , 17,000 miles .. 1971 Buick GS455 .. 2003 SVT Cobra .. 1971 GTO .. 1969 Camaro Fathom Green .. 1969 Camaro Hugger Orange .. 1970 Buick GS455 .. 1970 BUICK GS350 .. 1998 SVT Cobra 1900 miles;. 1973 STAGE 1 GS . 1971 Mach 1 351C 4 speed , first car. 1970 Mach 1 428 SCJ . 1970 SS 350 Camaro . 1971 442 ... 1968 Buick GS400 . 2015 Lexus IS 350 F Sport 2021 Badlands Bronco Sport |
The Following User Says Thank You to ScottG For This Useful Post: | ||
X66 714 (09-17-2022) |
Thread Tools | |
Display Modes | |
