Don't you dare! That and Rachel are the two things that keep you sane!
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
Against my better judgement, today I broke down and pulled the trigger on another clutch set-up--a McLeod RXT which is a dual disc system with ceramic pucs.
McLeod rates this unit up to 1,000 HP. With any luck I'll have it in the car within the next couple of weeks. Fingers crossed. |
Yeah!!
Did that dual-disc setup on the Performance Years board not work out? Seemed like a great deal. |
It had the wrong spline discs, would've cost too much to sort it out.
RXT clutch is in. All the gory details of the install are on my FB page.
Test drive report soon. |
Best wishes Eric!!
Sam... ![]() |
| The Following User Says Thank You to mockingbird812 For This Useful Post: | ||
VintageMusclecar (05-16-2017) | ||
The first test drive is in the bag--just a brief jaunt around the neighborhood, stayed close to home "just in case", but so far, so good.
The pedal effort is very comfortable, and as far as "driveability", I can already state that this is by far the most street-friendly clutch I've had in the car so far. Zero chatter, even in reverse, very easy to--for lack of better term--ride, not like the previous race clutches which were (to varying degrees) more like an "on/off' switch. I didn't lean on it at all, so as far as holding power goes, the verdict's still out on that. However, should this clutch perform as advertised, I will officially consider myself a McLeod convert. More soon--weather permitting. |
Keep your fingers crossed Eric -- sounds like you finally hit the right combination ... Craig
You've never lived until you've almost died -- for those who fight for it, life has a flavor the protected will never know! |
Sounds awesome Eric. I hope it will handle the power.
Jason |
| Thread Tools | |
| Display Modes | |
