Old 10-06-2005, 10:33 PM
quick-bowtie quick-bowtie is offline
Default 1969 Z28 WITH CROSSRAM AND JL8..EXCELLENT!!
The car is a real Z and Numbers Matching and has been discussed alot because of the ZZ stamping on the trim tag as of right now its the only Z to date with this on the trim tag (and the tag is original and never off the car) CRG cant seem to explain it but, so far it is 1 of 1 not that makes it worth more (because no ones seems to know what it means) but it is kind of neat..
The resto was done at Hatfields in Texas and Finished up by Coast to Coast Camaro, There is over 1500 hours in the resto, The car is very very nice. It has a factory GM JL8 rear end, Tilt, Endura Bumper, Console with gauges, 5 speaker Am/Fm Stereo, Original rosewood wheel (perfect), Factory GM Xram with dated coded factory original carbs (both Sept 1, 1968) All Date Coded Glass, 5 original correct YH wheels all dated 12/18/68, Correct original 4 clip trim rings, Brand New GoodYear Wide Tread GT's (real made in the US ones), GM spiral shocks, Original 837 alternator dated 12/18/68 along with original RARE #7708 Harmonic Balancer, 772 Fan dated Nov. 68 with correct eaton clutch, correct and original radiator with tag, original GM seatbelts all dated late 68', original T-3 headlights, All original and pulleys with part numbers, 9204 brake booster dated 316th day of 68' , correct 309 master cylinder and original cap, pefect endura bumper with correct brakets and hardware, GM NOS rear bumper, Correct 403 bellhousing, starter, shifter, four leaf springs etc etc.. If you really want to get into detail the car has its original GM radiator cap, correct GM NOS motor mounts and its original bolts. The car is correct and a REAL Z and not a restamped car. I have recipts on the resto and picture through out. The car is show quality through out.
VIN: 124379N580022
Cowl Tag info:
ST6912437 NOR222631BDY
TR711 52 B PNT
01B ZZ X33
Engine assy date: V1220DZ
Engine VIN 19N580022
Engine block number: 3932386
Engine block date L 12 8
Transmission date P9T18C
Rear Axle Code: QY 1010G1
Im asking $98,500 for the car..You could not begin to do a quality resotartion let alone find all the NOS date coded parts for that. Thought Id offer it here before I try other sources. Thanks for the post SYC. 507-208-0191 Andy
69 NASCAR PACECAR Camaro 1 of 7
68 Shelby GT500 Convert
Some other GM and Mopar
