Old 10-30-2003, 06:21 AM
mssl72's Avatar
mssl72 mssl72 is offline
Default Big Block Chevy Valve Cover Needed
I'm looking for a driver side valve cover for a 1966 big block Chevy. The valve cover should have the following: drippers, 2 spot welded clips for the temperature sender wire, 2 spark plug wire stand-offs and a small power booster notch that's about the size of a silver dollar. I've put 2 links here for 2 pictures that show what it should look like. You can see the position of the temp sender clips, the plug wire stand-offs and the size of the power booster notch. I'm looking for something that is very clean. Basically, no/minimal rust or dents. No repops. Thanks.
http://home.att.net/~mssl72/640valvecvr2.JPG
http://home.att.net/~mssl72/640valvecvr3.JPG
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
