Old 08-07-2002, 08:22 PM
will will is offline
Default Re: 69 SS nova big block car ????
last time! [img]/ubbthreads/images/icons/confused.gif[/img]
http://community.webshots.com/user/fastorange67
if these work you you tell if it's a 375hp car,also are the build sheet on the gas tanks on novas too,will this tell anything ???
thanks!
00 SS camaro
55 belair stockcar
68 chevelle 300
71 malibu (basket case)
Old 08-07-2002, 08:48 PM
JChlupsa JChlupsa is offline
Any idea where the Green 69 SS Nova came from. Does the person also have a Silver SS to match it. I know of a pair that was bought new in Freeport Illinois and sold as a pair to a person out east about 20 years ago. Would love to find the Silver SS. Had Deuces Wild painted under (4) Deuce palying cards spread out as a poker hand. Now that car was FINE. Both were BBC cars.
Old 08-07-2002, 08:57 PM
YENKO DEUCE REGISTRY's Avatar
will;
I personally can't tell that this car is a BB, or L78 if it is a BB. I don't know exactly how to determine if those engine perches are for SB or BB. It does have all three of the body decorations like the trim tag shows, and is rallye green. I'm not sure what someone was trying to do with the drivers side 1/4 panel?
Marlin
Old 08-07-2002, 10:06 PM
fastorange67 fastorange67 is offline
he was cutting the rust out to see if the inner panel was rusted ,its not.
Iam almost positive I've seen the dueces wild car before ,I'll keep an eye out for it!
Old 08-08-2002, 04:38 AM
bbdon bbdon is offline
Great, the pictures work now. I don't see enough to tell for sure that it is a big block car, but the signs do look good. The single fuel line tells you that it is not an SS350 or a 396-350 car. It could be a 396-375 car though. Where is the radiator support? There are lots of clues on it. If you can get into it, I would pull the back seat out to look for a broadcast sheet. You need to take some good wire cutters to get the sheet out without shredding it.
Old 08-08-2002, 11:16 AM
MikeA MikeA is offline
I can not access the pictures! [img]/ubbthreads/images/icons/confused.gif[/img]
Mike
1970 Yenko Deuce, YS-84
1972 Nova SS
1987 Grand National
Old 08-08-2002, 04:17 PM
are the GM 1/4'S the only ones that go up into the sail panel ????
00 SS camaro
55 belair stockcar
68 chevelle 300
Old 08-08-2002, 09:30 PM
Will
The GM 1/4's are the only ones that go all the way up the sail panel to the lead line. Novas do not have any build sheets or broadcast sheets above the gas tank, in fact, I don't know that I've ever seen a Nova build sheet. Like bbdon said, pull out the bottom of the back seat and check the underside corners for one of the broadcast sheets. If you find it, look for code Z26 for SS, and L78 for the 396/375hp. If you find a sheet, you should also find code B84 for body side molding, B90 for door frame molding, and maybe C07 for the drip rail moldings.
Marlin
Old 08-09-2002, 02:44 AM
Will, dii makes a quater that goes into the sail about 6in short of the lead line.Goodmarks did on the early stampings, but now are cut off at the bottom of the sail. Ken
Old 08-12-2002, 05:11 PM
what can I look for on the rad. support???
00 SS camaro
55 belair stockcar
68 chevelle 300
