Old 06-28-2025, 09:03 PM
JRSully JRSully is offline
Default Heater core
Looked on the floor of the garage and was not delighted to find a dripping pool of coolant under the Heater core area. When I restored the Nova back in 07-08. It had the orig BB core still in it and I had it restored/pressure checked etc by the shop that did my radiator. I guess a 17 yr run is not so bad. My question is should I have that original restored again or just put a brand new one in and call it a day.? My concern is even if the orig is restored, it is still 55 yrs old, with 55 yr old metal. Of the new ones out there these days, opinions on a good quality piece.? Tnx
71 Porsche 911 Targa
Old 06-28-2025, 10:19 PM
X66 714's Avatar
X66 714 X66 714 is offline
Send it to Glen-Ray radiator & have Bob give you his honest opinion of it....Joe
The Following 2 Users Say Thank You to X66 714 For This Useful Post:
169indy (06-28-2025), napa68 (07-02-2025)
Old 07-02-2025, 10:44 AM
Further to the heater core saga.. Any tips on either replacing the core from the engine bay side or dropping the box inside the car.? can you get to the cover attaching nuts that are buried under the pass side fender without pulling fender off.? Looking for any tips from past experiences
Old 07-02-2025, 11:55 AM
napa68's Avatar
napa68 napa68 is offline
He's my guy as well!
Old 07-02-2025, 01:20 PM
Too Many Projects's Avatar
There is no way the core is coming forward thru the firewall for removal.
If you can carefully remove the inner wheel house bolts and push it aside, you can access the heater box nuts near the fender with a 1/4" drive socket/loooong extension combo.
As an aside, the cores don't usually leak outside of the vehicle, as they are contained entirely inside. If the carpet/mat is dry inside, it may be a loose clamp or deteriorated hose ?
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
The Following 4 Users Say Thank You to Too Many Projects For This Useful Post:
dykstra (07-03-2025), enio45 (07-02-2025), napa68 (07-02-2025), YenkoYS-199Stinger (07-04-2025)
Old 07-02-2025, 02:55 PM
67since67's Avatar
This ^^^
Old 07-02-2025, 05:12 PM
Thx for the insight, will check the easy/obvious solutions first as you mentioned, maybe get lucky. The bolts on the inner fender are easy to get to and will go that route if necessary.
Old 07-03-2025, 01:28 AM
Kurt S Kurt S is offline
You can change the heater core from inside the car (seems the more popular way on youtube) or by taking it forward (often requires removing the whole fender/inner fender).
Kurt S - CRG
Old 07-03-2025, 02:24 AM
Well, there it is, never say never.....I've never heard of one being removed that way and it would still be a hassle to change it from the front. It does seem it could be possible with the removal of the inner wheel house and not mess with all the heater cables and duct work.... Shouldn't be any need to remove the fender, itself.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 07-03-2025, 12:29 PM
Talking
Tx All. IF I have to replace it, I like the inside drop idea as I would rather not mess with the current fender alignment, painted hardware removal etc. Again, maybe I get lucky here, and It's a hose or clamp
The Following User Says Thank You to JRSully For This Useful Post:
lpar1969 (08-20-2025)
