Old 04-04-2025, 02:43 PM
Grim70 Grim70 is offline
Default 1969 Muncie HD 3 speed back drive
I’m trying to find the number for the SB lower rod on a Nova. The lever and upper rod were shared with the four speed. My parts books and AIM are vague. The 3sp in the AIM is a Saginaw. Anyone have better info, setup in a car or parts in the stash?
Attachments - The Supercar Registry muncis 3spd.jpg munciehd 3speed.jpg IMG_1925.jpg IMG_1915.jpg
Old 04-04-2025, 03:51 PM
daveg's Avatar
daveg daveg is online now
This may help
https://4speedconversions-com.3dcart...m/3955767.html
Old 04-04-2025, 04:33 PM
Thanks. I’ve looked at that but from what I’ve found I think that is Saginaw so I don’t believe it will work. Although, hopefully I can verify.
Old 04-04-2025, 09:58 PM
daveg's Avatar
Curiosity kicked in.
Top pic is Muncie
Bottom pic is Saginaw.
First- reverse levers are in same place.
Your pics above show 1 Muncie and 1 Saginaw.
First- reverse lever shows same part number for both.
Why would the rod be different?
The Following User Says Thank You to daveg For This Useful Post:
Grim70 (04-05-2025)
Old 04-04-2025, 10:25 PM
Top pic is Muncie
Thanks for these. That is what I’m trying to verify for sure. Perhaps the shift levers are different on the Saginaw? I’m pretty sure the frame mount lever is different.
Old 04-04-2025, 10:38 PM
Igosplut's Avatar
Igosplut Igosplut is offline
Is this the setup you are talking about? This is a 69 Saginaw 3 speed HD from a big block Chevelle.
WOT
The Following User Says Thank You to Igosplut For This Useful Post:
Grim70 (04-05-2025)
Old 04-05-2025, 12:01 AM
If that is out of a 69 that is a Muncie MC1 3 speed. I don't believe a saginaw was offered for the chevelle that year either. There was a saginaw that resembled the muncie. Does the one pictured have the 5/16" two piece ball? Flat side shifter? Bench was flat buckets said muncie, I believe.
Old 04-05-2025, 01:00 AM
daveg's Avatar
Default sure looks like a Muncie to me
Looks to be a Muncie.
Old 04-05-2025, 01:54 AM
Rsconv68 Rsconv68 is offline
This?
The Following User Says Thank You to Rsconv68 For This Useful Post:
Grim70 (04-05-2025)
Old 04-05-2025, 04:25 AM
Originally Posted by Rsconv68 View Post
This?
See how everything is (ex HD). Also those are the shifter control rods.
