Old 01-18-2021, 10:18 PM
R68GTO R68GTO is offline
Default BDisc Brake Banjo Bolt Washer source
I'm having trouble getting my banjo bolt joint to seal. Seems it's a common problem due to replacement copper washers are harder than the originals. I first tried to seal mine with the original washers - no luck. Then bought a set of replacements with the same results. I've torqued the bolt up to 35 ft. lbs. and am afraid to go much higher (spec. is 25 ft lbs.) Anyone have a particular source they've used for softer copper washers?
Old 01-18-2021, 11:31 PM
John Brown's Avatar
I read they can be heated with a propane torch and allowed to cool to make them softer. Haven't actually tried it myself though.
John Brown
Old 01-19-2021, 12:13 AM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Yenko Advertising Member
Hi Jim. I’ve got a few new ones. I’ll send them to you to try out.
Cheers, Anthony.
Old 01-19-2021, 11:49 AM
Too Many Projects's Avatar
I'm having the same issue with replacement calipers on an '80 TA. I could feel the new washers where stiffer, but never thought about being too hard to indent and seal. Might have to try the annealing process.
Thanks for the tips...
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 01-19-2021, 12:43 PM
NorCam's Avatar
NorCam NorCam is offline
Hi Jim
I've had two sets of the ones available from HBC and they have always worked fine for me. I just installed another set on this yellow car and plan to bleed the system out real soon. I don't expect any problems with them as they have always been good for me in the past.
Old 01-19-2021, 12:55 PM
BARRY BARRY is offline
i had the same problem ..... i had the rubber hose on the wrong side . have a really good look at the end that has the copper washers .
Barry Allan
Old 01-19-2021, 01:22 PM
Originally Posted by norcam View Post
hi jim
i've had two sets of the ones available from hbc and they have always worked fine for me..
hbc ???
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 01-19-2021, 01:37 PM
RobR RobR is offline
Heartbeat City https://www.heartbeatcitycamaro.com/store/
The Following 2 Users Say Thank You to RobR For This Useful Post:
NorCam (01-19-2021), Too Many Projects (01-19-2021)
Old 01-19-2021, 02:13 PM
NorCam's Avatar
Sorry for not linking the part. Here are the washers I use.
https://www.heartbeatcitycamaro.com/...-GM%23-231343/
They also have new banjo bolts if needed. BRK-1083
Old 01-19-2021, 02:47 PM
Thanks for the link. I didn't know what hbc was. Too many acronyms now days for an old fart to keep up with...
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
