Old 11-04-2020, 12:03 PM
A Build sheet will call out the two letter code of the AC installed.If not have a build sheet,nor a Cowl. Ind. hood,the dual snorkel will be the hardest to prove,as the majority norm was open element.The plant & the DATE the car was assembled can also help figure if it came with a Dual Snorkel,as a very,very small % of LS-6's did.
Old 11-04-2020, 09:11 PM
L72Biscayne L72Biscayne is offline
Default Air cleaner LS6
The White LS6 car is a 06D built in Atlanta with CO in box 55.
Dave.
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
Old 11-04-2020, 12:53 PM
DWR DWR is offline
1970 Chevelle 396-350, 10-23-69 Atlanta build, box 55 air cleaner, code SS, has a base with the breather tube pointing toward the heater box like the base on the right.
The Following User Says Thank You to DWR For This Useful Post:
chris slawski (11-04-2020)
