Old 04-09-2022, 07:19 PM
frankk frankk is offline
Grahame do you know if the stock lifters had that feature?
Old 04-09-2022, 11:23 PM
NorCam's Avatar
NorCam NorCam is offline
No they did not Frank. And with modern oil not having the lubricity it used to...as well as the metallurgical properties having changed in the lifters and cams, these EDM lifters are the way to go with a little added lubrication of the lobes.
Helps to keep from wiping a lobe off the cam during break in is my line of thinking.
Old 04-09-2022, 11:40 PM
NorCam's Avatar
Quick shout out to Lloyd C. for hooking me up with an NOS new ash tray for the Rosewood dash that I just swapped into the car. It made for a nice upgrade since the original was scratched up. Also installed an MSD 8910 tach adapter to see if I can get this Green line tach working in the car. Jason sent me the NOS tach and stated it was tested but have not been able to get it to work as of yet. Hopefully this adapts the signal and gets it's operating as it should. If not it needs to go back and I'll hook something else up in it's place.
I'll fire it up tomorrow to see if the tach works with the adapter in place (fingers crossed). If it works with the 8910 installed, I can then button everything back up. Felt good to get working on the car after it sitting here for nearly 5 months.
The Following 5 Users Say Thank You to NorCam For This Useful Post:
169indy (04-10-2022), big gear head (04-10-2022), napa68 (04-09-2022), olredalert (04-10-2022), scuncio (04-10-2022)
Old 04-10-2022, 02:50 AM
Graeme,
I am very sorry to hear the tach is not working for you. As I said earlier, I tested the tach before shipping it to you and it worked well. That was over a year ago but time should not change anything. I have not heard from you in 6 months so I assumed you got it sorted. If you need to return it, I am ok with that.
Old 04-10-2022, 03:31 AM
Everytime I see the car I go ahhhhhh , what a sweet looking 69
The Following User Says Thank You to frankk For This Useful Post:
NorCam (04-10-2022)
Old 04-10-2022, 03:21 PM
NorCam's Avatar
Thanks Frank.
Going for a different look with it this summer. Installing new wheels and tires along with the cowl hood. Going more for a look like this except it has the Endura bumper and no style trim group.
A subdued look so the Popo don't give me a hard time on Portage Avenue this summer. They hassle car owners with skinny fronts and 50's on the rear. Perhaps it'll make a great little sleeper with the stock suspension height and 7" wheels under it. Until they hear that cam that is? lol
Example of the look I want with stock ride height and 7" wheels.
The Following 6 Users Say Thank You to NorCam For This Useful Post:
Donnie (04-10-2022), gtomike1967 (04-11-2022), L72Chevelle (04-10-2022), napa68 (04-11-2022), x77-69z28 (04-22-2022), Xplantdad (04-10-2022)
Old 04-10-2022, 02:29 PM
NorCam's Avatar
Sorry Jason...
Wasn't trying to flame you there. You've always been a straight shooter on everything my friend. I sent you a PM
Been lagging on the troubleshooting process of the tach only due to it being mounted up on the pillar for what was a labor intensive position. I finally took it down last month to chase the issue and run some other tests but that was interrupted with me selling my home and getting ready for a big move as I head east this month. Trying to finish this up before I move and get this sorted out before loading the car into a trailer.
I'll know where I'm at later in the day as I will test both the Green line tach as well as the stock in dash tach to ensure I have something working before buttoning it back up today. I'm hoping the SW works with the tach adapter and it goes back up on a halo mount, or I'll be looking for another pillar pad. lol
Old 04-10-2022, 05:36 PM
NorCam's Avatar
Grrrrrrrrrrrrrrrrr. Still no tach...and I tried both ways on both tachs (SW and Dash Mount). Wondering if it's something with the MSD box now? Anyone know what the ohms signal should be coming of the MSD gray lead? Going to pull out the meter next and measure what signal is coming of the box.
Old 04-22-2022, 02:06 AM
NorCam's Avatar
Finally got some 7" wheels mounted so I can strap it down in the trailer w/o the rear quarters bouncing off the tires as the car gets moved across the west. Gonna be fun shredding these tires this summer. Should also drop another inch when the cowl hood goes onto the front end. The stock rear shackles also need reinstalled and the spare tire also needs put into the trunk.
The Following 14 Users Say Thank You to NorCam For This Useful Post:
169indy (04-22-2022), 70LS6454 (04-24-2022), big gear head (04-22-2022), cruiserofland (04-22-2022), Dave Rifkin (04-22-2022), dykstra (04-22-2022), L78_Nova (04-22-2022), markinnaples (04-22-2022), RPOLS3 (04-25-2022), rszmjt (04-22-2022), Steve Shauger (04-22-2022), Tenney (04-23-2022), X66 714 (04-22-2022), x77-69z28 (04-22-2022)
Old 04-22-2022, 11:47 AM
dykstra's Avatar
dykstra dykstra is offline
Looks fantastic!!!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
NorCam (04-22-2022)
