Old 11-05-2019, 02:43 AM
XXXGoldL34M20's Avatar
Exclamation Muncie Shifter Assembly Spacer/Bushing Identification ?
Hi Guys, wanted to know what this MUNCIE Spacer or Bushing is called?
I have a shifter assembly missing this and want to buy it, looked all over eBay but no luck. It is made out of a hard type of plastic.
Any help much appreciated as it is for a member here and I would like to get one for myself too.
Attachments - The Supercar Registry sh_70PA30A_3.jpg s-l1600.jpg Muncie.jpg e0c1518c229a1cc1197f8866d6a92434.jpg
Old 11-05-2019, 05:23 PM
JoeC JoeC is offline
it is a rubber donut that goes on the main shaft bushing between the shifter and the mount bracket
originals are hard to find because the rubber gets hard and breaks
I don't know if anyone repops them
Some people make new ones from rubber grommets but its not the best solution
Old 11-06-2019, 02:22 PM
Thank You Joe,
Your right mine used to be a rubber donut that dried to a hard plastic and broke apart in a bunch of pieces.
I made a spacer donut that fits perfectly myself, bottom is a thin rubber washer, middle is a outside hose rubber washer and the top is a plastic nylon Oil Pan washer.
The fit is dead on in thickness and the center hole fit is dead on.
Better then having nothing.
Can't believe no company makes this out there oh well.
Old 11-06-2019, 08:33 PM
big gear head's Avatar
Can someone send me some very good drawings or an original part? I may be able to do something.
Freddie
Old 11-07-2019, 03:10 PM
I can get the dimensions but its not just a simple washer shape
it has a groove on the outside diameter
the inside diameter is undercut to lock into the bushing
The Following User Says Thank You to JoeC For This Useful Post:
XXXGoldL34M20 (11-07-2019)
Old 11-07-2019, 03:17 PM
this is what was left of mine after it dried up LOL
the orange dust cap is fine
Old 11-07-2019, 03:20 PM
If you can send me a cross section sketch and measurements I might be able to make it.
Freddie
Old 11-07-2019, 03:26 PM
dvss1 dvss1 is offline
Not hard to manufacture. I made a few out of hard plastic. Easy matching. Any steel or plastic supply houses have it or McMaster Carr.
Old 11-07-2019, 03:29 PM
Someone that has a 3D object printer should make these easily buy replicating a real one IMO (Do a color like this so you can keep on eye on it)
Old 11-08-2019, 06:36 PM
i pulled some dimensions off an original one
XXXGoldL34M20 (11-08-2019)
