Old 12-19-2018, 11:03 PM
The Following 4 Users Say Thank You to Charley Lillard For This Useful Post:
454_Malibu (12-19-2018), Canuck (12-20-2018), sixt9rsx33 (01-04-2019), southernfriedcj (01-07-2019)
Old 12-19-2018, 11:04 PM
Proper ammeter bypass
Old 12-19-2018, 11:05 PM
njsteve's Avatar
njsteve njsteve is offline
On the vertical face of the side of the block down by the oil pan rail on the passenger side, half way down the block. Its on a machined out three inch by one inch section.
Old 12-20-2018, 04:29 PM
RS_COPO_Canuck RS_COPO_Canuck is offline
Originally Posted by Charley Lillard View Post
No idea on the engine paint but probably that way since 88 at least. Runs good. Where are engine #'s ?
Engine date on top pad beside distributor. Should have a F (for 70 model year) 440 for engine size, and a month and day number. Should also have an HP or HP2 on there - hiding under the spark plug wire bracket. There could be other symbols as well for bearing size info etc.
Here is a pic of a 69 which has an E. 70 is F. Date is 4 8 ....which is April 8
VIN pad right side, above oil pan toward front of engine. Should match the trans VIN exactly
Old 12-19-2018, 11:22 PM
Google search looks like 2536430 is a 1970 service replacement short block.
Old 12-20-2018, 05:02 PM
That is a good casting number.
I have never seen any 440 block without a VIN pad....unless it's early....like maybe a '66-'68. Before they were stamping on the top rear of the block, near where the trans mates to the engine. After you stop bleeding have another look .
Wonder what the casting date is. Block almost looks turquoise in the pics....may be early.
Old 12-20-2018, 08:25 PM
What year is B ?
Old 12-20-2018, 08:26 PM
Old 12-20-2018, 08:30 PM
njsteve's Avatar
Is that a 4/18/1968 casting date code on the intake?
