Old 10-25-2018, 04:01 AM
Mr. Chevy's Avatar
Default What's is worth
1970 Chevelle 12 bolt posi rear end complete with GM 3:73 gears that were factory. September 1969 date code
Wondering on a value??
Thanks Rich
Old 10-25-2018, 11:16 AM
Default What's it Worth
Being it's a 3:73 and a September 1969 date, it would have most probably came in a 396 / 375 car. Only 3:31 and 4:10 came with MOST 454's. That being said I value it at $3500.00 FWIW.
Bill
Old 10-25-2018, 11:46 AM
BLACKLS5 BLACKLS5 is offline
What's the code on the tube? 3.55 would have been the standard gear for a 1970 L78 with 4.10 being optional. I don't think a 3.73 was offered in 1970 Chevelles.
The Following User Says Thank You to BLACKLS5 For This Useful Post:
Big Block Bill (10-25-2018)
Old 10-25-2018, 02:13 PM
It wasn't,but a 2.73 posi was,(Non SS)...could it be a 2.73 you have there?
The 1970 Camaro was available from the factory with a 3.73 though.
Old 10-25-2018, 02:52 PM
FWIW, I had a 10/21 stamped CRV rear. Seems a bit ahead of the game. IF I'm correct, chevy had everything in place for the 454 debut but the revised Muncie?? Kinda makes it seem plausible.
Old 10-25-2018, 03:27 PM
x77-69z28's Avatar
70 Camaro would be COZ coded for 3.73
Buddy
Old 10-25-2018, 03:33 PM
September 69 is way too early for a 70 Camaro , not to mention the leaf spring-coil spring difference.
Owned since 1978 - First Car
Old 10-25-2018, 05:08 PM
Agree,I wasn't trying to say he has a 3.73 COZ Camaro rearend there,(as I'm sure Rich knows the difference),just that that was the only 1970 Chevrolet car model that could get one from the factory I believe.
YENKO DEUCE REGISTRY (10-25-2018)
Old 10-25-2018, 10:18 PM
tunes's Avatar
tunes tunes is offline
I bought a 1970 Chevelle SS396 when I came home from Vietnam in early 1971. It had a 4-spd and the 3.73 posi. I can't tell you the build date of the car or the axle code because it wasn't important at the time. It does seem that at least a few were built with that ratio.
Robert
_______________
1969 Chevelle SS396 L78 M21 4.10
2023 Stingray Coupe Z51
Old 10-25-2018, 10:32 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
No 1970 GM A-body came with factory-installed 3.73 gears. Some Olds W27 option rear, W30 442 , 4-speed non-AC guys will try to say different but I have yet to see docs out of one of 'em.
I ain't nobody, dork.
