Old 02-05-2018, 12:20 AM
302moz 302moz is offline
Default 69 z sparkplugs
Does anyone know the correct ac spark number for a 69z? thanks
Old 02-05-2018, 12:39 AM
NorCam's Avatar
NorCam NorCam is offline
AC Delco Acniter R44 is the go to plug for Z/28 as far as I know. Many people run the hotter R45 and some have tried the colder R43 plug but they're usually not well suited to the street and tend to foul.
I got a set of R43 off eBay a couple years ago and last year got a couple sets of R44 from another member here on the forums.
Old 02-05-2018, 03:42 AM
If by "correct" you mean what it came with from the factory, that would be R43.
Most guys run R44. They don't seem to foul as easily. Some guys claim the R43 helps keep detonation down.
Old 02-05-2018, 12:05 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Checked my notes and the assembly-line correct R43 plugs should have 4 equal green bands and the word 'ACNITER' on the porcelain.
Tim in NSW, Australia
Old 02-05-2018, 03:39 PM
NorCam's Avatar
I have a box of R43N and the outer carton says "New" Acniter. Anyone know the difference between the R43 and the R43N?
Old 02-05-2018, 04:19 PM
John Brown's Avatar
R43 is a 3/8 reach plug (3/8 inch of thread).
R43N is a 3/4 inch reach plug.
John Brown
NorCam (02-05-2018)
Old 02-05-2018, 06:08 PM
In and out of the trailer or car show I would go to 44's or 45's John. 44's if you are going to drive it around. Take those cars out to the Curly Top or to get a newspaper on Saturday mornings Johnny. Its good exercise for them!
Honestly, I like my Holley's. They burn good winter-summer with no real issues.
Old 02-05-2018, 07:03 PM
olredalert olredalert is online now
----Big believer in Autolites in a driver!......Bill S
Old 02-06-2018, 08:54 AM
69L78's Avatar
69L78 69L78 is offline
I had to use 45's with my x-ram. I am with Bill on the autolites, they do not foul as quick.
Old 02-06-2018, 02:58 PM
x33rs x33rs is offline
I run Autolites in mine. I see better results with the heat range changes. I tune mine with a wideband to dial the carb in nearly perfect. Living up here at 5,000 ft I routinely drive the car down to sea level so I tend to tune where I find a happy spot for both.
I found the Autolite 86's work best. Equivalent to ACR45S (extended tips). They stay clean up here at 5,000 ft running just slightly rich 12.5-12.8-ish AFR's, and low to mid 13 AFR's at sea level. I stagger jet the carb for best results. Wife drives it daily up here and routinely gets 14.2-14.5 mpg with it in stop and go traffic.
The Following User Says Thank You to x33rs For This Useful Post:
wrench (02-07-2018)
