Old 11-09-2015, 09:54 PM
hubleyman hubleyman is offline
Default 1966 Chevrolet El Camino 396/325 - SOLD
1966 Chevrolet El Camino Pickup Truck / factory 396 A/T (not a clone) / SOLD
This car was built in December of 1965 in Fremont California and was delivered to Willows, Ca when new. I purchased it from the second owner, also in Willows, in 1990. It was very stock and original and virtually rust-free, with 66K miles on it at that time. Driven to roughly 74K miles before being disassembled.
As with many others, what basically started out as an “Let’s just paint the exterior” type of project turned into a body-off-frame effort. My intent was never for it to be flawless show quality trailer queen, more of a flashy cool car to cruise and enjoy, and it ended up coming out pretty nice overall.
Here’s some basic OEM info on the car:
1966 Custom El Camino / 13680
KK / Artesian Turquoise
710 / Two-tone Fawn interior – bench seat
L34 / 396/325 HP
M35 / A/T – column shift - originally Powerglide (now Turbo 400)
STD / 3.07 NON-posi 12 bolt rear diff
N10 / dual exhaust
A01 / Tinted glass - all
N33 / Tilt Steering Column
N40 / Power Steering
J50 / Power Brakes
K19 / A.I.R. (Air Injection Reactor = Ca smog)
Z19 / Convenience group: lights, remote mirror (removed by second owner)
U14 / instrument panel gauge package with Tachometer
??? / dash mounted bullet clock
U63 / AM pushbutton radio
G66 / Factory air shocks
A39 / Deluxe seat belts
V74 / Hazard warning switch
Runs very well. Engine was properly broken in, starts right up, choke works great, thermostat functions properly, etc.
<span style="text-decoration: underline">Let’s start with some unfortunate info:</span> Back in the 90’s I brought the born-with engine to a machine shop for a rebuild, along with several other big blocks I was working on at the time. I typically had blocks decked on my Hipo engine builds, and they accidentally decked this engine even though they weren’t supposed to. Because of that mistake, I pulled all my engine projects from their shop and never used them again. This project was then put on a back-burner for many years. So just for clarity, the block in the car is the original born-with engine block, but has no numbers on the pad due to being decked. I do have the codes from the POP, and maybe even a penciled impression of the original stamp somewhere in my files, but I’m not a fan of re-stamps and preferred to leave the pad blank instead.
And some good news: Most all the other components under the hood are born-with original as well: heads, intake manifold, carb, distributor, air cleaner base, complete smog system (including hoses), exhaust manifolds, all pulleys and brackets, alternator, starter motor, complete P/S assembly, master cylinder, fan shroud, etc.
Non original under-hood items: water pump (generic replacement), radiator, power brake booster (I have the unrestored original), valve covers and air cleaner lid (I have the originals, need to be re-chromed), 7 blade fan and clutch assembly (I have the original 4 blade fan), front end wire harnesses (new repro).
I replaced the original two-speed Powerglide with a three-speed Turbo 400 (which coincidentally was from a 1966 truck). The T400 was not offered in the Chevelle/El Camino until 1967, but I prefer them to the P/G. I acquired OEM 1967 column shift linkage assembly, kick-down switch and bracket assembly, rear trans housing and driveshaft yoke, etc. in order to make this a clean OEM looking and functioning installation.
Original body panels, except RF fender replaced by 2nd owner, LF fender replaced by me during resto (original had a tough dent to straighten on the front body line/nose, and I had a much nicer straight OEM fender to use), and the front below-grill valance panel.
Reproduction dual exhaust system with the correct staggered rear exhaust exits.
This car was built at the factory with a large quantity of inspection paint marks all over the place. I only duplicated a handful, but stopped short of making it a circus car. I have pictures of most of the OEM marks in case you wish to reproduce them yourself…
<span style="font-weight: bold"><span style="text-decoration: underline">What’s left to do (updated 03/02/2016):</span></span>
Install the new tinted windshield and rear glass (on hand), and trim (have all new repro trim, as well as the unrestored original trim).
A few troubleshooting tidbits I haven’t around to yet – very small drip from P/S pump, AM radio died (after installation, of course).
Front end alignment, headlight alignment, verify speedo calibration at higher speeds.
Touch up the paint on some suspension items (due to scuffing from floor jacks, jack stands, etc.).
Finish restoring the original Ca black plates.
Probably a few more minor items I am not currently thinking of….
<span style="text-decoration: underline">A little car history:</span>
The POP shows Harold Hendrickson as the original owner, being first sold on Dec 30, 1965, in Willows, Ca. He was actually one of the guys who pioneered fighting fires with aircraft, by retrofitting an old WWII airplane with some water tanks. Way back when, I tried to track him down but he had already passed away so I gave up that effort. On a research whim earlier this year, I thought maybe he had some children I could find who might remember this car and would have some stories to tell. Tracked down his son, Gary (who’s now into his seventies) up in the same area. Turns out Gary was actually the original owner of this El Camino, and dad Harold’s name was most likely just used for financing purposes. It will be 50 years ago this December he first got the car, and I promised him pics of it when it was done. He doesn’t do computers, so I need to print some photos and send them to him. He’s a vintage aviation guy just like his dad, with many WWII planes on his roster, and quite a few old cars to boot. Still drives his 1971 Ranchero that he bought new….
<span style="text-decoration: underline">Regrets:</span> If I knew this car was going to turn out so nice, I would have had the body shop spend a little more time on straightening out the bottom of the bed and lower rear cab area. My plan was always to install a rubber bed mat and add a tonneau cover, but now wish they put the extra effort in those areas to make the car even nicer.
Send me a PM, or email me at your convenience, and we can go from there. This sale is an effort to scrounge up some cash, so not really interested in trades…
Thanks, Charlie
