Thanks Bruce.
Well, spent a couple of hours giving it a good wash inside and out, then out for it's maiden Oz voyage. Drives real nice, could do with some stiffer shocks in the rear though. Will go in for a rear spring change shortly to lower the rear some, so I will change the shocks at the same time. Next week it will have a roadworthy certificate done, then off for registration and we can hit the road.
1969 SS 396/350 Chevelle |
Great news.
Must be tough waiting for a car like this in transit. Best wishes for the maiden voyage. Ryan
1969 Beaumont 350 Auto White Sold 1969 Beaumont 307 Auto Green Sold 1969 Chevelle SS 396-L35 Auto Blue Sold 1969 Oldsmobile Cutlass 'S' Sports Coupe W31 |
Damien,
Two sets of center caps just means....soon you`ll have another car arriving....this time shipping from the West [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] The Chevelle is Beautiful.....all your Mates will be impressed [img]<<GRAEMLIN_URL>>/headbang.gif[/img] Good idea in lowering the rear. Take some good pictures of the car.....and with you next to the car. I am content that your are happy with your new '69 Chevelle. Dan
69 300 Deluxe Post Sedan Frost Green 69 SS396 300 Deluxe Post Sedan Lemans Blue SOLD 70 Buick Skylark Post Sedan Gulfstream Blue 70 Buick Skylark Post Sedan Burnished Saddle http://m.youtube.com/watch?v=PM3DE8qI2NY https://m.youtube.com/watch?v=Yn4xEmGypUw |
Thanks Ryan, all went well. As I said earlier it is really soft in the rear suspension so that will need some attention, and a bit of a tune. The guy I bought it off used to run a bit of an av gas mixture, for what ever reason, so it needs a little timing adjustment and a couple of small things.
Here ya go, Dan. The cat that ate the canary! ![]() ![]() ![]() Now has a standard steering wheel, as per the buildsheet. Just waiting for a new '69 centre badge.
Ok, after a bit of suspension investigation, it turns out my car has no hop bars fitted. I have absolutely no experience with these, I understand what they do, but have a couple of questions if anyone can answer;
Is there any effect on ride height? Perhaps this is why the rear suspension is so soft? Can I just remove these, replace the bushes and re connect the top trailing arms? Should I leave them in, lower the rear and stiffen up the suspension? (I must say I would rather lose them and take it back to stock!) Any info on this would be appreciated. Thanks.
As far as I know......
They don't affect ride height. They are a bolt on so they should easliy go away after replacing upper bushings. I hope they aren't the style that requires holes drilled in the rear end case? There is my 2 cents. Ryan PS: Great pictures.
Damien,
Great pictures.....Thanks. The bet the lower ears of your rear end are indeed drilled.....I have a set of these on one of my Chevelles. They do raise the car a bit....If you do want that Chevelle stock height.....I would remove them. What is your son`s name? Dan
Thanks for the help, guys.
Dan, my son's name is Joel. If the rear end has been drilled out, I would say I could have a poly bush machined up to return the arms to the stock location?
Damien,
They are drilled at the webbing of the rear end, no machining required. You can easily weld up the holes, no worries Mate [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] Joel is a Cool Dude! Thanks for the pictures. Dan
Dan, how will these bars affect handling as far as cornering. They dont look like they would be great for lateral movement?
| Thread Tools | |
| Display Modes | |
