Old 06-01-2008, 08:23 AM
Default Rear End whine
Since I got my car the rear gear has had a noticeable whine.
I pulled the cover off and looked around and didnt see anything unusual. The ring & Pinion are stock gm 373.
Before I get to far into this are these rears commonly noisy or what are the opinions pertaining to conditions which could cause this????
Thanks
Carl
Old 06-01-2008, 08:32 AM
Default Re: Rear End whine
Improper lash, carrier or pinion bearings, low fluid, M22 trans, stereo not loud enough.
Old 06-01-2008, 08:41 AM
Would a bad bearing cause excess clutch chatter or grabbing????
Carl
Old 06-01-2008, 08:32 PM
68CamSS 68CamSS is offline
Whine accelerating=lash too tight
Whine coasting=lash too loose
Whine always=bearing or bad gears
Old 06-02-2008, 01:42 AM
temp cure per old used car salesmen = banana peels or saw dust.
Old 06-02-2008, 04:49 AM
I'll have to check, I never really noted if the whine is constant or not. The date on the gears match the range which would indicate they are original to the car, so I guess if they have been improperly set for long enough they may be worn. Thanks for the info, I've never really been up speed differential stuff guess nows the time to start.
Thanks for the help
Carl
Old 06-02-2008, 06:09 AM
x  Baldwin  Motion's Avatar
oh yeah... it's right there on the bench, just throw 'em in !!
