Old 04-24-2008, 06:07 PM
Hemi_Joel Hemi_Joel is offline
Default How to ID a 12 bolt rear end?
Hi,
I have a 12 bolt rear end from a Chevelle or something similar that I am thinking I might want to part with.
How do I identify it and figure out the date codes and stuff?
Thanks, Joel
Minnesota Hemi Guy
Old 04-24-2008, 06:46 PM
Default Re: How to ID a 12 bolt rear end?
As well as what this diagram shows,relay all the letters and numbers lightly stamped in the passenger side axle tube usually facing the floor board,or front end.
The casting date & CON1 locations have been found to interchange between those locations shown,and also at the 4 O'clock & 8 O'clock positions.
[i]Drawing Courtesy of Camaro Research Group)
Old 04-24-2008, 06:49 PM
John Brown's Avatar
Hi Joel, see if this helps.
General info.....
http://www.chevellestuff.com/qd/gene..._axle_info.htm
Axle codes....
http://www.chevellestuff.com/qd/axlecodes.htm
Everything you ever wanted to know about Chevelle rear ends (well almost).
John Brown
Old 04-25-2008, 01:57 AM
Thanks guys!
I'll be checking it out this weekend to see what it is.
Old 04-25-2008, 08:17 PM
H8tulooze's Avatar
H8tulooze H8tulooze is offline
Send a message via ICQ to H8tulooze
Good info Joe Brown. Thx
1965 Malibu SS Convertible
1967 Nova SS LS1 Sold!
1967 Nova SS LS9 800HP
1970 El Camino SS396 4/Sp
Old 04-26-2008, 12:13 AM
RPOL88 RPOL88 is offline
The first thing I look for is the taper on the tube behind the flange. Chevy uses press in bearings. B O P tubes are straight. Bolt in axels.
