Old 02-25-2008, 05:08 PM
JHS JHS is offline
Default COPO wiring harness help needed
Trying to find the correct front engine compartment wiring harness for '69 COPO Camaro. I need the alternator harness that has the plastic torpedo-like attachment tab (supposed to be brown but told they only come repro in white) to the upper alternator bracket hole. I ordered what I thought, and was told, was correct from Rick's but it is not. Thanks.
'70 L78 NOVA SS
'77 Bronco
Old 02-25-2008, 05:23 PM
Default Re: COPO wiring harness help needed
I have ,in the past, removed the brown clips and horded them for use on new harneses where they show.
I think you will find that the plugs for the headlamps are clear, rather than brown. You can swap these around too.
Maybe someone has a source for the brown gizmos
Mike
Old 02-25-2008, 06:50 PM
JHS JHS is offline
Mike
The harness that Rick's sent has no clips at all. The harness currently on my car is not long enough to route up to the alt. bracket and attach, even if it had a clip so ssume it is not original.
'70 L78 NOVA SS
'77 Bronco
