Old 02-15-2008, 10:12 PM
sixpakjoe sixpakjoe is offline
Default Chevrolet HP small block distributor.
Chevy Small block HP distributor, part # 1111478,Date code 2D18. Believed to be removed from Chevelle 327-325 HP engine. Excellent condition. Has been disassembled,bead blasted, shaft checked for straightness. Bushings are like-new condition. Includes Accel points and condenser kit, Part # 101 (GM standard RPM kit with 23 oz. springs),distributor cap & rotor kit, Part #8124 (high performance kit with brass inserts) and Taylor Thunder Volt 8.2 mm factory replacement Ultra High Performance ignition wire set, Part # 84001, black color with 90 degree boots. All parts are brand-new in original boxes. Distributor is in like new condition. $220.00 for everything. Contact [email protected]
Old 02-15-2008, 10:47 PM
69L78's Avatar
69L78 69L78 is offline
Default Re: Chevrolet HP small block distributor.
Joe, I sent you an email.
Old 02-15-2008, 11:45 PM
Hi Jeff, I replied to your e-mail. Will hold the parts for you. Joe
