Old 12-22-2007, 01:46 AM
Chris396 Chris396 is offline
Default Head gaskets for aluminum heads
I'm swapping my iron L78 heads for a set of 842 aluminum heads along with a '69 tripower for something a little different and Day 2. What head gaskets do you recommend to use with the aluminum heads, and what head bolts and washers should I use?
Old 12-22-2007, 03:51 AM
Default Re: Head gaskets for aluminum heads
Ken should know...Kwhizz...you out there?
Old 12-24-2007, 07:41 AM
Anybody?
Old 12-24-2007, 08:01 AM
Nova Jed Nova Jed is offline
An engine builder told me something about Fel-Pro making good aluminum head gaskets.
Old 12-24-2007, 07:15 PM
Make sure they have the stainless steel rings in the gasket.And yes the fel pros should work fine. Make sure you torque them correctly, and recheck after running a few miles.
Old 12-24-2007, 07:24 PM
VintageMusclecar's Avatar
What year is your block? It makes a difference whether it's series-cooling or parallell-cooling as to which style of head gaskets you use.
Eric
