Old 11-17-2007, 08:52 PM
camaro41701 camaro41701 is offline
Default X-22
I just bought a X-22 car.Matching #'s with POP.The car was wrecked early in its life and the left side of the firewall was bent.It is wrinkled pretty bad around the fender bolts and sunk in at the cowl tag.Fenders,doors,and hood aligns well.It has been pulled on but still looks bad.
I am going to change the upper cowl and outer left cowl panel.What would be the best thing to do with the hidden vin on the upper cowl?Should I take plenty of pictures to verify what has been done and section it back in or just keep the partial vin in the other paperwork for the car.
I know what I can do legally so I am not looking for a big discussion on legalities,just what would be correct as far as what would be the best for the car itself.This is not something I am going to try to hide if I decide to sell it.
Thanks
Old 11-17-2007, 10:15 PM
Unreal Unreal is offline
Default Re: X-22
I'd save the cowl, even if you have to disassemble the whole thing to have it straightened and reinstalled. I would not remove the cowl tag.
But if you insist, lots and lots of pics are a must. I would not weld the hidden VINs back on the new cowl. I'd save the whole cowl with hidden VINs and TT.
But again, I'd straighten the original cowl!!!
Old 11-19-2007, 06:29 PM
YENKO DEUCE REGISTRY's Avatar
Default Re: X-22
I'd save the cowl, even if you have to disassemble the whole thing to have it straightened and reinstalled. I would not remove the cowl tag. ....
Ditto. It's more work to remove, straighten, and reinstall - but it will be the original cowl, no explanations necessary regarding a replacement.... yada yada. Take lots of pics of the removal, straightening & reinstallation.
Marlin
Old 11-19-2007, 07:21 PM
Default Re: X-22
I will try to post some pics as soon as I get the car apart.It is wrinkled pretty bad on the drivers side.If someone else had not been messing with it before I got it it would have made things a lot easier.
As far as being easier I can change the panel a lot quicker.I do this for a living.If it had been any other car I would not have second thoughts.I would just replace.
Thanks
Old 11-19-2007, 09:14 PM
Default Re: X-22
Oh, I misread your post...if you want quick and easy, replace it or fill it with bondo, and paint over it.
Just my opinion, but if your interest is preserving the integrity of the numbers, I'd straighten the original without removing the VIN tag or trim tag.
If that's not in the cards, I would save the entire cowl. If you section in the hidden VINs, the car will always be suspect as possible rebody.
Old 11-19-2007, 10:53 PM
Default Re: X-22
I am not wanting Quick and easy.I am just wanting it to look good when finished,and not being critisized for changing parts.The person that fixed it last done more damage than good.After I get the fender off I can tell more about it.
I am normally not a #'s guy anyway.But,all the #'s are right on this car so I was thinking of putting it back.If it is going to turn out to being slammed every time I am out in it I wil just go ahead and build it the way I like,mini tub,4-bar,and 5-speed.
Thanks
