Old 10-08-2007, 10:28 AM
70Z28RS5151 70Z28RS5151 is offline
Default 1969 Camaro trim tag
Why are Van Nuys cowl tags stamped VN or LOS? Was this random throughout the 1969 production or did they make a change midway into production? When did they make the change?
Old 10-09-2007, 03:40 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Default Re: 1969 Camaro trim tag
Made the change about midway in December.
Old 10-09-2007, 05:09 AM
tabooo tabooo is offline
Was the tag stamped LOS midway into dec.& then the change was made to VN?
Thanks
Old 10-09-2007, 05:12 AM
Okay... thanks Jonesy. Here's another question pertaining to my trim tag, because I can't read the first digit in the build date. The caulking that was used to fill the rivet is covering the first number. I don't want to chip away at it... knowing me I will cause damage.
The number that I can see is 2D. My question is can you figure out if I have a 12D or 02D car? The body number is VN210907.
If this helps, the rear is dated BU 1220 G. I am thinking I have a 12D car, but I just want to know for sure what it is. My car does not have the original block.
Any help would be appreciated.
Tony
Old 10-09-2007, 05:42 AM
Hey,Tony I have some info. if your vin# starts after 510584 and not exceed 513816 it's a Dec.car,if it start with 520248 and not exceed 525388 it's a FEB. car. Please note that the above vins are for VN cars only.
Old 10-09-2007, 07:08 AM
Kurt S Kurt S is offline
12D
Kurt S - CRG
Old 10-09-2007, 09:24 AM
Yes 12D
Thanks, Tony
