Old 09-26-2007, 08:53 AM
RUQUIK RUQUIK is offline
Default Anti diesel solenoid-L78s
I have a question about the anti-diesel solenoid that came on L78s. Was this on all of them? I have a heavy red wire in my car and it is covered with the same stuff that the temp gauge wire is covered in. I am pretty sure that is what it is for.; Next question, does anyone have one with the brackets and intake bolts?
Thanks
Roy
Roy
Camaro Concepts, Inc.
2236 Blalock
Houston Texas 77080
713-365-9000
www.camaroconcepts.com
Old 09-26-2007, 09:05 AM
Default Re: Anti diesel solenoid-L78s
It was on the turbo 400 cars but not on the 4 speeds. The later GM harness came with that extra wire.
Old 09-26-2007, 08:35 PM
Thanks Charlie, My car is a t-400 car. You don't happen to know where I might find this stuff do you?
Thanks
Roy
Roy
2236 Blalock
Houston Texas 77080
713-365-9000
Old 09-26-2007, 08:53 PM
PM sent..
Old 09-26-2007, 10:12 PM
92646 92646 is offline
I have one that came off of a 71 Z/28 in my garage somewhere, are they the same? I saw it about 2 months ago while I was looking for some other parts. I will sell it at a fair price if it will work.
Mark Sheppard
Old 09-28-2007, 07:16 PM
"I have one that came off of a 71 Z/28 in my garage somewhere,are they the same?"
I wasn't aware of the Anti-dieseling solenoid useage in 1971?
Could you mean the unique 1971 one piece transmission controlled spark advance solenoid & throttle pot?
They incorporated these two devices into one single unit in 1971,then made them seperate again in 1972,after field results showed the two incompatible.
Old 09-28-2007, 07:10 PM
This anti-diesel solenoid was not on all L/78 cars. I have
seen early cars without them. The solenoid & bracket are
available from Heartbeatcity ( look on epay ). I don't
know for sure if there was a specific date this unit was
phased-in. The original solenoid part number is all but
impossible to find. Big bucks when they pop-up.
I had looked into this issue several years ago as I was
working on an L/78 THM400 combination for an early build
'69 Camaro. Since the original wiring harness was gone,
I could not verify the existance of the solenoid on this
car. I ended up buying the complete setup anyway just in
case I needed it. Since I never learned the date or
specific reasons this solenoid was installed, I put it on
the back burner.
Nuch
