Old 08-10-2007, 02:28 AM
copo69's Avatar
copo69 copo69 is offline
Default '69 Camaro brake caliper problems and questions
I have a problem with my '69 front calipers. First I had problem with car pulling to right so I changed the brake hoses, (few miles but 12 yrs old with silicone fluid) still pulled a bit but after dragging brakes for about 1/2 mi it cleared up and was fine however had a leak between caliper and brake hose fitting. I cannot get the leak stopped. I checked caliper for cracks, none, and hose appears OK. Seating surface on caliper looks OK but didn't get good crush marks on copper washer but it was correctly torqued then slightly over torqued and still leaked. New washers ere about .003 thinner. This leak was static. I removed caliper inspected everything again and bench tested with air but still get leak. I'm ready to pull my hair out. Anyway, I'm just about ready to replace the calipers although I hate to give up these as I'm 99% sure they're original and had them resleeved with stainless by Stainless Steel Brakes 12 or so years ago. I looked at the catalogs and I see "technically correct" so I assume same caliper used for other years. Anyone know what is correct casting #'s for '69 and how many years they were used? One catalog lists cars made before and after 11/69. I can't find any info on numbers anywhere...books or on the net. Anybody know what we need to look for? Any rebuilt calipers better than others? What is the correct finish on 'em...black paint or natural? What are the restorers using? Thanks
Old 08-10-2007, 03:11 AM
njsteve's Avatar
njsteve njsteve is offline
Default Re: '69 Camaro brake caliper problems and questions
Find thicker copper washers. I remember hearing somewhere that they changed the thickness and composition of the copper washers and they dont seal correctly on older cars anymore. They just dont have the same crushability/sealing power the original ones did. Even if you have to find an old set of used ones just to test them out, try that.
Old 08-10-2007, 04:19 AM
budnate's Avatar
budnate budnate is offline
had the same problem 2yrs ago on the '68..searched hi and low and never found thick washers just the cheasy thin ones even special ordered in a plastic kit full of diff sizes thinking I would get some good ones, it was hell!! mine would barely weep.. I gave up and shipped the car and worked it out with the buyer with new calipers, I assumed the rebuilds I got were not good, maybe not?.
Old 08-10-2007, 04:25 AM
Greg, Steve is right about using the older used washers...didn't mention that in my PM...I ended up using the original washers(37 yrs old) with some new brake hoses and calipers and they worked fine the thicker oem style washers will make for a better seal, especially with silicone fluid. Give it a try..
wilma
Old 08-10-2007, 05:50 AM
Mr. Chevy's Avatar
I agree with the others, try another copper washer for starters before doing anything else. This is the easiest fix to try. The color of the calipers should be black. I believe 1613 semi flat Krylon will work just fine. If you want to replace the calipers Napa carries rebuilts that are identical to the originals. They have the Delco stamping on them. Another thing you may want to consider or check is the fluid level in the master cylinder. You DO NOT want to top it off using the silicone fluid. You want to leave the fluid level approx. a half an inch down from the top of the master reservoir. Silicone fluid will expand in the closed system. Hope this helps ya...
Rich
Old 08-10-2007, 06:19 AM
copo69's Avatar
I have some ordered from GM....maybe I'll get lucky and get some from the bottom of the bin. Do the rebuilders resurface the seat on the calipers? If not could have the same problem with new rebuilds. I know the new washers are a diffferent color than the old ones and appear harder. Maybe a different alloy? I've considered doubling the washers.
Old 08-10-2007, 04:21 PM
Mr. Chevy's Avatar
I believe the rebuilds are re-surfaced. I know people that have used them and had no problems...
Rich
