Old 05-15-2007, 06:52 AM
Alss's Avatar
Alss Alss is offline
Default extra thick BBC valve cover gaskets
Anyone have a source for these??...need something about 1/2 to 5/8 thick..cork...trying to clear some poly locks on a stock appearing motor. Thanks
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 05-15-2007, 07:09 AM
427.060 427.060 is offline
Default Re: extra thick BBC valve cover gaskets
Someone makes an aluminum spacer that will do what you need. If you don't want to use a spacer, you could use 2 cork gaskets.
James
1968 Beaumont SD396
Old 05-15-2007, 09:53 AM
sztuty sztuty is offline
Albert
Just finished biding a stock L78 and used roller rockers-hence the need for a little extra clearance.
There are aluminum-core gaskets made, as well as just a thicker gasket (laminated with a metal core as well)
I ended up needing the thinner of the two and I got the learance I needed
Ty
Old 05-15-2007, 10:16 AM
92646 92646 is offline
ALbert, I think McCord makes a double thick gasket that has a metal shim bonded between the 2 halves. If you can not find a set e-mail me. I found a really trick set of valve covers that are a little higher than stock on one side with the dimple for the power booster and the welded on spark plug tabs. These look stock at first inspection but clear roller rockers. I found them brand new on e-bay last year. Let me know if you want more information.
Old 05-15-2007, 03:37 PM
Alss's Avatar
Thanks guys..I knew someone had to be making these. where can I purchase them?..part numbers?? Thanks
ALbert
Old 05-15-2007, 03:45 PM
bbbenny bbbenny is offline
Al, I got mine from jegs. 1/2 cork look like orginals except thicker. I got them on the car, now.BBBenny
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Old 05-15-2007, 04:14 PM
Go to NAPA. Victor Renz part # VS38420H.
Made in USA and just a little more money than the thin ones.
Great deal!
Peter
