Old 03-29-2007, 01:26 AM
jasonL78 jasonL78 is offline
Default SBC engine identification help!
Just got and old 70 pick up truck with what looks like a mid 60's 327 or 350. It has the breather on the intake. I got the engine pad info 18c123675 TO02I9HC. I can't get to the block casting until I pull the motor it is to close to the fire wall. I found one website that said 69 350 out of a A,F,X body is this correct. This is a 69 350 I think coded for a M/t
Old 03-29-2007, 01:36 AM
Default Re: SBC engine identification help!
That code was shared on nearly everything from 1967-1969.
Specifically your CON VIN & February 19th of 1968 engine code is saying it originally came in a 1968 Passenger series 327/275HP 4bbl w/PowerGlide trans. assembled at the Southgate Calif. plant.
Old 03-29-2007, 02:40 AM
Thanks alot for the reply. I thought the 1 was an I that makes more sense.
Old 03-29-2007, 04:41 AM
I checked the engine pad again it is 18c123675 T02I9HC. What does the I stand for in the suffix I thought that was the month?
Old 03-29-2007, 04:51 AM
Tarrytown SS427s Tarrytown SS427s is offline
The one probably was an I, and it was common for I's to be used in place of ones. On my 68 427 the code says TIIII1E, when it actually should say T1111IE
Steve
Steve
68 SS427 Custom Coupe 427/385/M21/3:73
68 Impala Custom Coupe 427/425/M21/3:73
68 Biscayne 2 Door 250/3 speed
68 Caprice Estate
68 Camaro SS396 4 speed
Old 03-29-2007, 08:18 AM
Fast67VelleN2O's Avatar
Sounds like you got yourself a large journal 327
Day 2 is Life.
