Old 03-10-2007, 12:32 AM
Default 302 Clutch and roller rocker info needed
What is everyone running for clutches on their 302's?
Would like something with a little less pedal pressure and as good or better clamping force... been so long since I bought a clutch... WOW been thinking about using a double disc wondering if there is a good alternative?
Also is there a needle bearing roller rocker that will fit under stock valve covers... with drippers?
Old 03-10-2007, 12:42 AM
mudjnky mudjnky is offline
Default Re: 302 Clutch and roller rocker info needed
Centerforce usually has good pedal feel with higher clamping force as the RPM's go up. I ran one on a street car with no problem.
http://www.centerforce.com/
Old 03-10-2007, 12:48 AM
Center Force is a good set up. 1 clutch disk is fine. I have a Hayes in mine but I don't think it is as good as a Centerforce. (To lazy to change it). I use the Comp Cams Magnum rockers with the roller tip. The Cranes are good too. I Don't believe they will fit under the drippers though. Try them. You can always grind the drippers off if you want. I did that before and they worked fine.
Old 03-10-2007, 12:58 AM
DarrenX33's Avatar
This is what Sam recommended to me when I built my motor. I used the Comp Cams stamped steel rollers. I am happy with them. I did need to snip the ends off the drippers with a dremel..
1969 Z28
1972 Corvette
