Old 03-02-2007, 04:45 AM
quick-bowtie quick-bowtie is offline
Default Show car display..need help
Just curious if anyone knows where to buy the lifts/blocks you put under the tires on a car display..It looks like they raises the car up 4 to 6 inchs..I want to put a set of mirrors down but I want the car raised up alittle.. I saw alot of guys at Barrett with them so Im hopping someone knows. Thanks Andy
69 NASCAR PACECAR Camaro 1 of 7
68 Shelby GT500 Convert
Some other GM and Mopar
Old 03-02-2007, 05:09 AM
Default Re: Show car display..need help
Here's two different places to check Andy!
Discount ramps
Aluminum tube ramps
Old 03-02-2007, 04:32 PM
70 copo 70 copo is offline
Try the local Lumber store. Use 2X10's as base material and 2X4's, 2X6's or 2X10's for the wedges.
Determine the elevation you want on the car, cut the lumber and create the pile. Next Lag screw them together. Then align the tire on the pile to get the center. Make sure the car's weight is on the tire when placed on pile, and as with any jacking operation chock the other tires for safety)
Next add the 2x4 wedges (chocks) that you have cut and hammer them tight. Mark the locations. Remove the wedges and the pile from the car. Lag screw the wedges onto the pile where you marked them.
Prime the wood. Finally Paint the entire pile assembly the color you want to match the other display materials. You are all done. I think I have about $75.00 in materials in all four pictured here when I did them, and the best part is that you can make them higher if you want later.
Tools you will need - a Good radial arm saw, Lag screws, primer-paint and brushes.
Phil
Old 03-02-2007, 10:47 PM
CamaroKing CamaroKing is offline
www.hitchesonline.com the jiffy jack aluminum ones are the best.
