Old 02-22-2007, 05:03 AM
Default 1970 L/78 Nova brake valve setup question
Hi all !
I have a fast question I'm sure someone can answer rather
quickly. A friend is restoring an 02-C-1970 L/78 Nova and
we ran into a problem with the brakes. Disc brake Nova's
used two different junction blocks, brake valves, and
pressure regulator valve setups depending on the build date.
We believe there were two different setups used ( early vs.
late ). It appears that the early build used the same setup
as that used on the 69 Camaro.
Can anyone tell me what the cutoff date was for one setup
vs the other? Also, if we need the later setup, can
someone post an image of the complete assembly at the
master cylinder location so we can see the routing of the
lines, etc.?
Steve
Old 02-22-2007, 06:57 PM
YENKO DEUCE REGISTRY's Avatar
Default Re: 1970 L/78 Nova brake valve setup question
I don't think the cutoff date has been determined. There are mid-year 69's without the block on the subframe, and early '70's with the block on the subframe. So, it's best to use what you found. If everything was missing, and you don't know, go without the block on the frame. Check out Gregg Robert's site for pics, someone's got a link I'm sure.
Marlin
Old 02-22-2007, 08:49 PM
L78steve L78steve is offline
There was never a block on the frame.The original line is still there but thats it all else is gone.I have a good reference picture that shows the brass Texas shaped valve mounted to the right (pass side) of the master.And the pic.also shows a brass distribution block with 3 segments.What I mean by 3 segments is the forward junction for front lines,Then the balance switch then a junction for the line from the Texas valve to the rear brake line.And lastly a junction at the rear of the block that accepts the line from the rear port of the master to the Texas valve.Is this set-up common on the late 70 novas?
Old 02-22-2007, 09:41 PM
Yes.
Marlin
Old 02-22-2007, 09:56 PM
Any idea where one can find one of these brass distribution blocks?
Old 02-22-2007, 10:08 PM
jasonL78 jasonL78 is offline
I have one!
