Old 01-01-2007, 10:28 PM
Lino Lino is offline
Default Hurst Comp Plus in stock console
I am putting a Hurst Comp Plus in a 69 Camaro. I would like to use the factory console . The handle I have does not look like it will come through the console or the trans tunnel (without trimming) in the right location. Has anyone done this before.Which handle should I get or do I need to fab one up ? Thanks in advance for any help.
Lino
Old 01-01-2007, 10:34 PM
Default Re: Hurst Comp Plus in stock console
The Hurst CP handle # you need for the console is 7436. I used my local Speed Shop to get it from. Sam
Old 01-02-2007, 12:33 AM
budnate's Avatar
budnate budnate is offline
takes a special shifter tower with the right offset as well, seen some that look right but are from something else and hit the tunnel in the lower left of the hole. been there,doh.
Old 01-04-2007, 07:31 AM
P.J. P.J. is offline
IT is imparative that when ordering a shifter and handle that you order the correct one for your 69 with council or it will not fit.
I ordered mine from summitt along with the assembly kit.
PJ
