Old 11-07-2006, 06:41 AM
@wot @wot is offline
Default Engine Block painting
What is the best way to prep and then paint a Chevy engine block? Looking for info on primers, types of paint, correct colors, etc.
Dean
Old 11-07-2006, 06:51 AM
Default Re: Engine Block painting
It's a real pain to work with, but I love the POR products.
Old 11-07-2006, 10:13 AM
If it's a fresh rebuild, the prep is mostly done when its tanked to clean metal. Otherwise, its tedious work to prep an engine. A lot of cleaning and scuffing in all the nooks/crannies.
We paint engines with pretty much the same process you would use for the outside of the car, and with the same products. Epoxy/etch, sealer/primer, BC/CC (sometimes single stage) with SW product.
Dont know the exact terminology or product #s, I dont do the paint/body stuff.
TheMuscleCarGuys.com
Old 11-07-2006, 07:42 PM
IF you are over restoring a car then by all means go with the primer ... epoxy combo... however if you are looking for an authentic restoration then a light covering of an original type product from a spray gun is how they were done at Flint and Tonowonda. If you look at orignal unrestored cars they have minimal paint on the engines.
Here is a link to pics of a very low mileage LT1...
http://www.chevynova.org/1970LT1_Engine.html
Old 11-07-2006, 08:40 PM
YENKO DEUCE REGISTRY's Avatar
I understand the lighter the coat of paint, the longer it will last because it allows the heat to evaporate. If you load it up with primers, base & clear, it will peel off quicker. Any truth to that?
Marlin
Old 11-07-2006, 08:41 PM
true that.
Old 11-07-2006, 11:45 PM
All good info. I was either going to simply spray a hi-temp paint or go the primer, base coat etc route. I will probably just use a can of hi-temp paint.
Dean
Old 11-08-2006, 03:31 AM
Donnie's Avatar
Donnie Donnie is offline
I use plasti-kote engine enamel and gray engine primer. just a light coat of primer and you wont get the cast bleeding back through the paint.
ENGINE ENAMEL and Primer
Resists Temperatures up to 500°F (260°C).
Race Tested.
Will not Burn Off, Chip or Peel.
Oil Resistant.
Color Choices are Exact Matches to Original Engine Manufacturers Standards.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 11-09-2006, 01:49 AM
How does powder coating look? A local shop will do engine blocks, heads, etc. It should be fairly durable.
Old 11-09-2006, 01:59 AM
What would it cost to powder coat a block and all associated parts?
Dean
