Old 09-23-2006, 02:49 AM
Default M&H RACEMASTER slick decoding needed!!
I need help decoding a pair of NOS M&H cheater slicks I have. Each tire has an old brown shipping label which says M&H RACEMASTER WARETOWN, MASS on it. They were shipped to California Speed & Sport Shop, Jersey Ave. New Brunswick, NJ. These tires have two segmented circumficial grooves in the slick surface and two very fine raised circumficial ridges on each side about 1/2" below the meat of the slick. (sorry, if I had a camera, I could post pictures)
Each tire has the following raised lettering: 7.0/30.5-15, NOT FOR HIGHWAY USE. Each also has an indented mold mark (between the typical 2 screw holes) with raised numbers 130. ( I believe this may be the compound #) Each tire also has yellow crayon writing on the contact surface that says,
7.0
30.5
130
One tire has a raised R-7 and one has F-7. One tire also has a mold plate (with the typical screw heads) with J491706. The other has J491805.
I'm always amazed at how Rick can decode OEM tires, but I was hoping someone could decode these M&Hs for me. The raised large letter M&H RACEMASTER logo is in outlined letters, but with no white ink anywhere. One tire has a white ink stamp about the size of a postage stamp with 2 characters in it, but I can't make them out (maybe a letter and a number?)
I mainly would like to know what date these tires are. And any other info would be greatly appreciated. (or any leads where I can find it)
Thanks guys!
Verne
Old 09-23-2006, 02:58 AM
Belair62 Belair62 is offline
Default Re: M&H RACEMASTER slick decoding needed!!
Those are new repops..I'll give you 50 bucks for them
Old 09-23-2006, 03:05 AM
Go soak your head!
Old 09-23-2006, 03:06 AM
396L35's Avatar
396L35 396L35 is offline
They are new repops..I'll give you $100 for them!!!!
Mark
Old 09-23-2006, 03:21 AM
Come on guys.................
If these turn out to be the right dates, I already have the perfect car in mind.......
That short person in Chicago can probably guess what it is..............
Verne
Old 09-23-2006, 04:52 AM
Vern, I have a 71 catalog that those tires are listed in exactly. 130 and 131 are the compounds. Sam
Old 09-23-2006, 05:18 AM
'71 huh? I was hoping they might have been offered about 8 years earlier.... Does the description describe what that compound was suited for?
I hope someone can DATE these tires.
Sam, I appreciate your input. Thanks for the response.
Verne
