Old 09-16-2006, 05:09 PM
71Nova454 71Nova454 is offline
Default Urgent: Need Advice On 454 BBC Headers For 71 Nova
Hey Folks,
New guy to the forum here. I'm posting this for my dad. He just bought a 71 Nova with a 1970 454 Big Block
Chevy motor in it. The car needs new headers and he's not sure what size tube to go with as well as
brand/model.
He's not sure what headers are on it and isn't sure what the previous owner installed.
The 454 has been bored over something like 50thou and is a streetable motor running at 9.5:1 compression. It
has a 750 Holly with a mild cam. The car is running true dual exhaust through Flowmaster Mufflers. A local
mechanic that does a lot of work on high performance engines told him the car was probably putting out an
estimated 450-470HP.
The car has a 4 speed transmission with a 3.73 rear-end.
The car also has power steering.
There's not much room to work with. He said the headers that are on there now only clear the power steering
box by about 1/4".
He's wanting to get some reasonably priced headers that won't affect the power he's getting from the motor and
the overall performance of the car.
So knowing all of that he asked me to find out...
1. What size header tubes would you recommend?
2. What's the best choice for Max. HP considering the clearance issue.
3. What brand/model would you recommend?
I guess the mechanic my dad took the car to said he's had some problems installing Hooker Headers in some of
his rigs. Reading some of the posts in this forum, I see that a lot of people seem to have problems getting the right
fit.
My dad's wanting an easy install and doesn't want to sacrifice any power. That's not too much to ask right?
He's been reading that perhaps sticking with the smaller 1 3/4" tube size might be better than the 2"+ sizes....Any
feedback on that also?
Hope to get some responses from ya'll...The sooner the better...The car has an exhaust leak now that you can
smell pretty bad while driving the car so he's looking to get the new headers installed ASAP.
Thanks for you time,
Michael
For My Dad, Terry
Old 09-16-2006, 06:20 PM
396L35's Avatar
396L35 396L35 is offline
Default Re: Urgent: Need Advice On 454 BBC Headers For 71 Nova
Welcome Mike... As for the header problem have you tried to call Summit or Jegs and talked to a tech??? I have never installed headers on a nova so I cant tell you what to look for but the only clearance problem I see would be the steering box collumn.. Sorry maybe someone else can chime in soon as they wake up... Mark
Mark
Old 09-16-2006, 06:42 PM
mnyenko mnyenko is online now
To get a good header fit. You need to replace the small block frame and motor mounts with big block. That will give you clearance on the steering box. Hooker super comps are a good choice. Earl
Old 09-16-2006, 07:11 PM
markjohnson's Avatar
mnyenko is correct in that you need to replace the frame mounts with the proper big block frame mounts. These are relatively cheap and any of the Nova restoration companies will carry them. They will move the motor away from the steering box giving you the clearance you need. As far as headers go, buy the Hooker Comps #2457 for $159 from Jegs. They have 2.00 primaries, great spark plug and starter access and are very easy to install. Trust me on this. Great header for the money and it sure beats paying over $400 for Hooker Super Comps.
Old 09-16-2006, 08:55 PM
92646 92646 is offline
I went though this with my 1969 Camaro with the 454 and 540. I ran Dougs short 1.75 headers first and I was very impressed with quality but the tube interfered with the power steering box so I had to dimple it. I went to Hooker 2.0 super comps the next time and the fit was better. I installed the headers in the car with the motor in place and it was more work than expected. I would recommend pulling the motor out of the car and placing the motor back in after you put the headers in position. Then you can replace the motor mounts and stands at the same time. I went to urethane mounts and gained a little more clearance in place of the original style mounts. I also ended up replacing the exhaust system with a 3 inch system to work with the bigger headers because I was not happy with the transition from the 3.5 collector to the 2.5 exhaust pipes.
Mark Sheppard
Old 09-17-2006, 01:32 AM
AutoInsane AutoInsane is offline
What are the coatings on the Hooker headers? Are they prone to rust after a while? I Jet Hot coated the exhaust manifolds on my CJ-5 10 years ago and not a spot of rust to this day. Might be a good time to get them coated when you buy them. I highly recommend it.
http://www.jet-hot.com/
They sell coated Hooker and other brands of headers for your Nova too:
http://www.jet-hot.com/pages/Precoats/Nova.htm
Bill O'Brien
1974 Jeep CJ5 - 304 V8, Edelbrock Intake, Holley 650, MSD Ignition, Patriot Headers
Old 09-17-2006, 11:14 PM
Jeff Murphy Jeff Murphy is offline
Go here or have your engine builder go here: HeaderDesign.com
Register at the site and use their calculators. You'll get accurate information for your particular engine's characteristics (including things like "Exhaust Port Length in Cylinder Head", "Performance Factor (how will you use this engine)", etc. You won't be sorry (and you'll probably find out that VintageMusclecar was right on the smaller tubes). Then you can find the right header manufacturer for you based on price, fit, etc.
The big tubes always look tougher but aren't necessarily the right performance answer.
Jeff M.
ZL1 #49 (Dale, Waukesha WI) Super Stock restoration by SCW; 9561AA (Walters, Hebron OH) Super Stock motor by the Grump
Old 09-18-2006, 11:28 AM
Thanks again guys...Yeah, when I talked to him last night he was saying he's been thinking of keeping it small...So 1 3/4" seems to be a pretty common recommendation.
Since he's having this mechanic in town do the job for him, he's wanting to work with him as much as possible. (Don't want to piss a good mechanic off..especially in a small town).
Dad likes Hooker Headers but since the mechanic has had problems installing them, dad's looking at other brands. Since all headers rust eventually he's not looking to spend a ton of money on them.
-Michael
Old 09-18-2006, 06:15 PM
lowmile lowmile is offline
I have run FloTec headers. They fit perfect, yes even better than Hooker. You can get them already coated and they hold up fine. A set of coated Flo-Tecs will be about a 100 bucks cheeper than uncoated hookers. m
Old 09-19-2006, 01:04 PM
Thanks again guys...I guess he's found a header shop up in Eugene Oregon and headers and performance exhaust is all that they do. I think he's going to take it up there and let them fool with it. I guess they've got like 200 different styles of headers.
Dad started having second thoughts about having someone work on his car that has a tendency of blowing their tops! Can't say I don't blame him. He also found out today that the ones that are on there are Hedman Headers...Not sure about the tube size though.
He's leaning toward the FloTec's...
