Old 08-10-2006, 12:07 AM
Default Need photo of Upper and Lower Rad Hoses for 69 Z
Does anyone have a photo of NOS or Original upper and lower Rad hoses on a 69 Z? I am specifically looking for a photo of the part numbers / GM markings and of the stripe that was used to ensure correct placement.
The Repo's are no where close to correct!!!!
Thanks
Old 08-10-2006, 05:37 AM
Default Re: Need photo of Upper and Lower Rad Hoses for 69 Z
I have a set of NOS hoses on one that I'm building now. The lower is correct, the upper is for 68 I believe.
But youre right. After looking at the "correct" repops, I chose to go with the NOS upper even though the p/n is wrong.
I can get some pics tomorrow if no one here has any by then.
dave
TheMuscleCarGuys.com
Old 08-10-2006, 04:55 PM
Thanks
I am going to make a stencil, silk screen, or stamp so I can replicate the original lettering and logo but most of all I want the yellow stripe on the hose that shows the correct position. The repop stuff is so bad that it made me laugh? If you are going to go through the trouble of reproducing something... do it right!
I really wish there was a Chevrolet reproduction parts supplier that gave their view/opinion of the quality of the parts... much like Ames does for Pontiac.
They give you the low down and then you can make the decision on whether to buy it or not, if it is not right they tell you, if it is all that is available they tell you that as well... Sure would be
Old 08-10-2006, 05:46 PM
kwhizz kwhizz is offline
Thanks
First gen
Imagine That!
Ken
Old 08-11-2006, 03:21 AM
Here's a few I took today. Have a few more I can email if interested.
dave
Old 08-11-2006, 03:38 AM
Dusk Blue Z Dusk Blue Z is offline
I took a look at the hoses from my car which I think are original, I've owned the car 27 years. My picture came out pretty bad but I can work on it if you want to see them.
The top hose does not have any writing left on it but under where the hose clamps were, you can see a BLUE stripe, that runs the whole length of the hose. The stripe is 1/8" wide and looks like it was put on with a perf. wheel. As the hose is mounted to the radiator the stripe would have been at about the 1 Oclock position and runs straight down the hose. It has 1/4" letters of A U C cut into the rubber 5 times during the whole length.
The lower hose has GMAU with 3942561SM under it printed in White, 2 1/8" from the radiator end printed straight up so you could read it. This also looks like it has the same BLUE line, but it is harder to see. The cut letters from end to end are A U A A B A U A AB
After re-reading this I think I better work on getting better pictures or just send you the hoses. Questions?
Mike
Old 08-11-2006, 03:46 AM
Thanks for the replies everyone. The little bit of research I have done so far has turned up different fonts, font sizes, and stripe colors...
