Old 07-08-2006, 12:37 AM
NovaMob03 NovaMob03 is offline
Default Yenko found?( or just an interesting Camaro)
Back in January I was given a lead on this car by Dan Palchanes. I purchased it as it had many obvious copo traits, but after closer inspection, comparing the vin/body # to other X 11 Yenkos & talking to other site members I thought it could be a Yenko.
The car is not listed on the sYc, but I'm hoping that by bringing it up for discussion someone may have additional information or documentation that may be helpful to me. It is listed on Ed's copo.com database.
I've also asked Bruce to post a few pics so that you can see it the way I found it.
It has: 140 speedo, date correct/orig BE rear, multi leafs, tach mounting holes in dash, hole punched thru the firewall, SW sender holes in firewall/rt side of cowl tag, exhaust frame plate hangers, sgl 3/8 fuel line, hole in accelerator arm, heavy duty torsion rods for spoiler trunk, date is 03B. It's also a column shift automatic, which according to Warren D. was certainly possible.
It's missing the curve neck radiator, HD sway bar, orig engine & CX tranny. It was a drag car & the front brakes were converted to drum.
With the help of camaromb, kurtS, copo & mark K. I was able to identify (8) X-11 cars & this car's body # falls, pretty much, right in the middle of them.
Many thanks to the site members that have already helped me & to Ed for the certification and to Dan P. for the hook up. If any one has any additional info on this car(9N616128) or 9N616828 I'd appreciate it very much. I also appreciate the opportunity to post this info as I expect it to be somewhat contreversial. Thanks Tom & Rob
Old 07-08-2006, 02:00 AM
Default Re: Yenko found?( or just an interesting Camaro)
Here are the pics from Jude...
140 Speedo
Old 07-08-2006, 02:01 AM
BE rear
Column shift auto (with tilt)
Old 07-08-2006, 02:04 AM
Tach mounting holes in dash
Old 07-08-2006, 02:05 AM
Hole punched through firewall
Old 07-08-2006, 02:43 AM
jeff morocco jeff morocco is offline
why would someone want drum brakes for drag racing??
i took my drums off and went to disc.........very interesting
Old 07-08-2006, 02:52 AM
COPO COPO is offline
I saw this car the day Jude brought it home and knew instantly it was a Yenko. No question in my mind it is the real deal. Just goes to show when you think everyone has been found, another one is uncovered so keep looking.
In regards to disc brakes being converted to drums. This is/was extremely common on drag cars. My 300 mile 69 Z-28 was a drag car from day one and has drums up front. Discs always have some drag, where as drums roll without dragging making the car just a bit quicker.
Old 07-08-2006, 03:05 AM
bilede bilede is offline
Jude, has anyone been able to run NCIB on the car. having all the copo pieces but that would tie it to yenko once and for all.. you da man!!
Old 07-08-2006, 03:46 AM
Yes, Bill. Unfortunately, the car didn't turn up. BTW it is a Fathom Green no vinyl top car
Thanks Bruce for posting the pics
