Old 06-26-2006, 11:58 PM
enio45 enio45 is offline
Default Starting a car in hibernation for yrs
I have an 87 el camino V6, 10K miles sitting in storage for the past 6-7 yrs. I never started, did nothing to plan it for storage. Just covered it with a good car cover and in a secure garage. Im planning to bring it out this yr and make a daily driver out of it.
Any recommendations of what to do - first, just getting it started, and then road ready?
Appreciate the thoughts......
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-27-2006, 06:00 AM
indyjps indyjps is offline
Default Re: Starting a car in hibernation for yrs
change the oil, pull the plugs, wd40 the cylinders and spin it over by hand, turn it over with the starter with a battery charger hooked up, (may want to pull the valve covers and make sure none of the valves are sticking), drain the gas out of the tank and carb, refuel see if it will start. will most likely need a battery, alternator, carb rebuild, radiator flush, oil change, thermostat cap rotor plug wires would be a safe bet, may even service the trans, run it a while and check your hoses, vacuum gremlins and water leaks are a big possibility. things like the manifold/heat riser valve seize up sometimes on those, heater core may be shot if the coolant in it was bad, brakes will need to be checked before any driving (hoses included) it all depends on how well it was stored you may get off lucky on some of it but be safe and do the brakes.
Old 06-27-2006, 07:06 AM
BBIGG BLOCK 396 BBIGG BLOCK 396 is offline
if you really want tp get serious pop out the distributor and us a priming shaft on a drill and run it until it starts oiling at the rockerarms,but do all the other things mentioned above first!
Bobby Dodson
Old 06-27-2006, 10:18 AM
Thanks for the advise guys, this is in line with what i was thinking.....did not think about the heater core issue. Bobby, i like the distributor idea....
Indy, why do you think the alt may need replaced??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-27-2006, 09:36 PM
I have always had good luck with pulling the plugs and squirting a few shots of Marvel Mystery oil in the cylinders, wait a few days or more then spin it over with no plugs then fire it up. Marvel works wonders with stuck valves and rings... if it seems like you have either stuck rings or stuck valves after firing it up...
with the car running and Aircleaner off rev the engine and pour marvel mystery oil into the carb... we have used this method to unstick rings and valves in engines that have not been started in over 40 years.
Old 06-29-2006, 02:13 AM
Thanks for the tips on Marvel oil,,,,,were do you buy this,,local parts store?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
