Old 04-21-2006, 06:12 PM
Alss's Avatar
Alss Alss is offline
Default L-72 tune up
Well my COPO runs!!but.........its very sluggish on the bottom side of the RPM range. I have 12 degrees intial advance but it doesnt seem to want to run at anything below 1200 RPM and as soon as any load is on it it want to stall!! Anyone have any tune up specifics I can use to help this monster run any better?? Jeyy Macniesh did the distributor and it is set up for a L-78 motor not a L-72 if that makes any difference. Cam is a solid roller .575 intake and .597 exhaust 112 degree lobe center..not real radical..I can get the cam card later if needed. Thanks
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 04-21-2006, 06:20 PM
TDW TDW is offline
Default Re: L-72 tune up
Al, I would disconnect the vac Adv and set the total timing to 38 degrees. Hook the VA back up and see where it is then.That is how Jerry had me do mine. I had to the change the Vac canister, but it runs good now.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 04-21-2006, 06:29 PM
YENKO DEUCE REGISTRY's Avatar
Sounds like my car when I first fired it up!
It's hard to diagnos remotely, but I had to set my idle high because the mixture screws were off - K.Marple fixed that up for me, big thanks. My car wanted to fall on it's face when I stabbed the gas because of the idle circuit, so I installed the white pump cam in hole #2 (I think), and that cleared up the off-idle stumble.
Make sure your plug wires are correctly routed, I made that mistake once too - a few guys from Kansas helped me correct that mistake at Englishtown Also, simply make sure they are all connected, I had one drop off last year at SCR8 - couldn't figure out why I went from 14.2's to 15.5's!
I agree with Tony on the distributor, yank the vac adv hose, and set the timing for 38 degrees at around 2000 rpm. That should eliminate the distributor as a major culprit, and then you can focus on other items.
Marlin
Old 04-22-2006, 04:39 AM
@wot @wot is offline
Run nthe rpm up high enough to achieve max centrifugal advance, then check the timing and set for about 36 degrees without any vac advance. You'll need a decent dial back light to get an accurate reading. Test vthe car, pull a couple of plugs and check for any detonation, and finally make any minor timing adjustments to the total timing. Then connect the vacuum advance and test again for detonation.
Dean
Old 04-22-2006, 04:57 PM
JimM JimM is offline
I like to work backwards, start the tune for good idle, tip in response, and midrange, then recurve the mechanical advance for the correct total timing.
Most of the cars I've tuned like a LOT of initial, assuming you're not ping limited due to too much compression. My car runs GREAT with 18 degrees initial and another 18 from vacaum on full manifold. That's right, idling with 36 degrees in it!
As long as it will crank hot, and not ping at part throttle with the vac advance unhooked, you don't have too much initial. If it pings at part throttle with vac advance, get an adjustable canister and tune it out.
Continually work the idle speed, idle mixture, and then power valve / primary metering rods as you do this.
Jim
http://www.firstgens.com
Old 04-22-2006, 05:48 PM
Chevy454 Chevy454 is offline
Post the cam card...being it's not the GM cam, and that it looks fairly larger than the original 143, it may just be the cam is weak down low because of the cam timing/duration and what not...
