Old 03-05-2006, 07:25 AM
JB1 JB1 is offline
Default '68 Firebird: Conversion to Delco HEI
Hi. I am converting to later model Delco HEI distributor in my '68 Firebird. Any place I can obtain proper how to instuctions? I do not want to use a kill switch unless I really have to. Thanks,
John
Old 03-07-2006, 08:54 AM
indyjps indyjps is offline
Default Re: '68 Firebird: Conversion to Delco HEI
is it going to fit the firewall, i know on camaros there is always a clearance issue. what engine are you running.
Old 03-07-2006, 04:27 PM
MosportGreen66's Avatar
I run HEI in my '70 350 Camaro and the GM unit fits perfectly on the back of the engine.
I cannot see any real issues fitting distributor back there... I got to have a least an inch or two remaining
Old 03-08-2006, 02:21 AM
on a 1st gen camaro with a small block it generally takes a hammer to make an hei fit and allow for adjustment, motor mounts can be swapped to make it work a little better.
what engine is in the firebird?
