Old 01-19-2006, 07:45 AM
Alss's Avatar
Alss Alss is offline
Default 69 smog question
WHere does the vacumn from the diverter valve connect to the source..carb?? There is a port but it is used to supply vacumn to the choke poll off. All the pics I have are cars with the air cleaner on. Ready to hook mine up. Thanks
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 01-19-2006, 08:25 AM
Default Re: 69 smog question
That's the correct vacuum port to use for both the Diverter & the choke pull off.
It should be under the front bowl where it meets the intake.
They used a white 3 way plastic Tee to coordinate all 3 hoses.
In 1970 they added a TCS solenoid,so they used a 4 way Vacuum tee.
Old 01-19-2006, 08:31 AM
Alss's Avatar
That's the correct vacuum port to use for both the Diverter & the choke pull off.It should be under the front bowl where it meets the intake.
Rick..any source for that "T"??
ALbert
Old 01-19-2006, 08:32 AM
I have found my local hardware store sells a damn good match to the original.
I have some 3 ways and 4 ways here,if you want I can send you a digital pic later tomorrow?
Old 01-19-2006, 10:49 AM
Anyone got a good clear image of the "T" with the vacuum
lines installed? I see white 3-way T's on eBay from time
to time, but I thought they were 1970 components.
Steve
Old 01-19-2006, 06:03 PM
Alss's Avatar
Rick, that would be great thanks..no real hurry..just wrappimg up loose ends.
ALbert
Old 01-20-2006, 09:19 AM
The middle store bought is much whiter and has an extra rib at each end,but is the same measurement as the original.
