Old 12-17-2005, 10:26 PM
jfkheat jfkheat is offline
Default 427 Block Question
What car would a August 1967 cast 427 IT code block be correct for? What heads should it have come with? What would a standard bore block with no damage be worth?
Thanks, James
1968 Beaumont SD396
Old 12-17-2005, 10:53 PM
Enoch Enoch is offline
Banned
Default Re: 427 Block Question
Without looking it up I belive that is a Corvette designation for L-88 so an August dated block would be for a 68. Whats the casting #'s 351 or 321? It should be a 4 bolt main also. Could you post the full Tonowanda stamp.
Rich.
It should have 842 aluminum heads.
If there is no vin it would be worth quite a bit to some one with a 68 L-88 Vette with the wrong motor. Also that is what Motion put into some of thier cars, so if anyone has a Phase III 68 anything that would be the correct motor fo it.
Old 12-17-2005, 10:59 PM
It's a 321 4 bolt block. TO822IT stamped on the pad with a 8 19 7 cast date. I haven't seen the block. I don't know if there are any other numbers on the pad. It is on Ebay. The seller gave me a price that he would end the auction for but I'm not sure if it's worth what he wants.
James
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8023316056
1968 Beaumont SD396
Old 12-17-2005, 11:02 PM
Banned
That's for sure a 68 L-88 built motor with an early build worth picking up. How much do they want? and if your not interested may I have a shot at it. Thanks,Rich.
Opps just saw the ebay link thanks anyhow.
Old 12-17-2005, 11:09 PM
Does the pad stamp look ok?
James
1968 Beaumont SD396
Old 12-17-2005, 11:17 PM
Banned
Yes with the "T" floating at the end that is how a lot of them were stamped. I can't make out the broach marks I think the block was glass beaded. (or just a poor picture if you are serious ask him for another shot of the pad.) However the rusted outline of the head gasket is still present so I don't think it was decked.
Old 12-17-2005, 11:31 PM
Banned
James, sent you a PM...Rich
