Old 10-31-2005, 09:30 PM
69L72RS 69L72RS is offline
Default Early chevy parts
55 to 64 Chevy posi 3rd member:
· NOS M/T magnesium 3rd member
· Posi unit (EC tight)
· 5.13 ring and pinion (FC spotting)
· Item is not assembled
I am asking $1300 OBO or trade + shipping.
1962/3 T-10 for Corvette or Impala
· all Aluminum case
· 3-ring Nickel 2.20 close gear set
· “S” code VIN
· output shaft has twist
· will verify VIN and date code
I am asking $1000 OBO or trade + shipping.
Eric
1-937-748-4254 after 7:00 in Ohio
I would take a Sept. to Nov. of 1959 tach-drive gen. As partial trade on either of the above items.
Old 11-01-2005, 02:28 AM
Belair62 Belair62 is offline
Default Re: Early chevy parts
Sent you a PM Eric
Old 11-01-2005, 04:32 PM
Eric,
Would you mind posting (or PMing) the VIN and assembly date stamping from the T-10? also interested in the cast date on the side of the case. T10-1C or T10D-1?
If that rear would be a '59-'64 Olds/Pontiac, it'd be sold!
thanks
Verne
Old 11-01-2005, 04:55 PM
Verne,
I will get the numbers from it tonight and post tomorrow.
There is a guy in Indiana that has a bunch of the pont/olds
aluminum and mag cases. I will see if I can find his number for you.
Later,
Eric
Old 11-01-2005, 08:18 PM
Thanks!!
Old 11-02-2005, 04:31 PM
Verne,
I checked the trans this morning before work.
The trans tag didn't match the tranny.
I must have sold the other one at the last show and mixed up the tags. I hate getting old and forgetful.
The tranny numbers are:
main case = T10-1C / dated 9-2-63 / stamped WA642
Tailhousing = dated 11-14-63
Couldn't find a VIN stamp. I will look it over better tonight.
It is also a 3-ring 2.20 gearset. Output also has twist about 3" in.
What would this trans be for?
I haven't found tim's number yet.
Eric
Old 11-02-2005, 06:07 PM
The T10-1C case was used in '61 &amp; '62 only in production (although Pontiacs may have used it a little longer - not sure). Since it was cast in Sept '63 and assembled WA642, which is January 6th, '64, 2nd shift, I'd be inclined to think it was a service replacement, and probably without any VIN. Also, no Chevy early T-10 had an input with 3 rings. so, again, it "might" be Pontiac, or perhaps a different gear set was installed in the case at some point.
Verne
