Old 09-26-2005, 03:49 AM
jfkheat jfkheat is offline
Default Decisions, Decisions, Decisions.........
Since I blew my engine in my 68 Beaumont this weekend I have a decision to make. Do I try to find a correct 396 and try to redo the car as close to original or do I find another 427 and build it like I want? Since the original engine is long gone, the car will never be a numbers matching car but it would be nice to redo it like it came from the factory. On the other hand, I like the extra power of a slightly modified 427. There are so few Beaumonts left so I will not do anything to change the look of the body or interior. If I go with another 427 I still want the car to look like if came from the factory with the exception of the engine compartment. What are your opinions??
Thanks, James
1968 Beaumont SD396
Old 09-26-2005, 03:55 AM
mike s mike s is offline
Default Re: Decisions, Decisions, Decisions.........
if money is an issue i would go with the 396 if its not i would put a 427 in the car and build a correct 396 on a stand to have for correctness
Old 09-26-2005, 04:20 AM
TDW TDW is offline
427. Without a doubt.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 09-26-2005, 05:18 AM
Alss's Avatar
Alss Alss is offline
Build a 427 and make it look like a 396..engine compartment as well
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 09-26-2005, 05:31 AM
COPO COPO is offline
Is the block cracked on the 427 in the car? Why not just rebuild it? Keep the extra power of the 427 and likely the cheapest way to go.
Old 09-26-2005, 06:01 AM
427TJ's Avatar
427TJ 427TJ is offline
I like that idea.
Old 09-26-2005, 06:09 AM
Thanks for the comments. I think it would end up costing more money to put go with the 396 and make the engine compartment look like it did when it left the factory since very little under the hood is original. Finding the "correct" 396 parts will take time. If I go with the 427, I want more of a Day 2 look. What I end up doing will probably depend on what damage I find when I pull this engine. I'll have to see what I can reuse. I'll probably start work on it tomorrow. I moved the car today and there was a puddle of antifreeze under it. Not a good sign.
James
1968 Beaumont SD396
