Old 09-08-2005, 04:54 AM
A468BU A468BU is offline
Default Question about a 68 nova
Hello everyone,
I'm new poster long time reader. There are some very knowledgable people in here so i thought I would ask this question here. My friend has a 68 Nova thats a drag car. About 2 year ago it went on the back bumper and came down pretty hard. It had to have the frame straighten and everything was ok for a little while. Well the frame is moving again. What i need to know is, Does anyone know the measurement between the front shocks? Maybe someone out there is in a middle of a resto and can measure this for us.
Thanks
Brian
1979 Chevrolet Malibu
468 BBC PG
9.71 @ 135mph
Attachments - The Supercar Registry 157723-FrameDiagram.JPG 157650-68ChevyIIandCamaroFrameDimensions.JPG
Old 09-08-2005, 10:54 PM
Default Re: Question about a 68 nova
It will be the same as any 67,68,69 camaro Hope this helps
Jake is my grandson!!
Old 09-08-2005, 11:08 PM
Anyone have that measurement?
468 BBC PG
9.71 @ 135mph
Old 09-09-2005, 12:11 AM
I have two frames separated from cars right now and can get it for you tonight if someone else doesn't get it before then (and if I don't forget).
Lynn
Old 09-09-2005, 12:41 AM
that would be great thanks
Brian
468 BBC PG
9.71 @ 135mph
Old 09-09-2005, 07:51 AM
If the frame was straightened, how is it moving? Did you drop it hard again? If it was straightened correctly , it shouldn't be moving unless it's cracked and flexing, or moving at the mounts.
Old 09-09-2005, 08:14 AM
Brian:
Almost forgot you. Late night tonight. From shock hole to hole, center to center, is 35.5 inches.
Measuring the inside of upper control arm mount, from side to side is 30.5 inches.
Hope this helps.
BTW, while measuring these two frames I noticed something I had never noticed before. On the driver's side only, by the upper shock hole is another hole, slightly smaller. Any ideas what that is for?
Lynn
Old 09-09-2005, 10:15 AM
JChlupsa JChlupsa is offline
Not sure if this will help or not. Got this from the 1968 Chassis Service Manual
Old 09-09-2005, 07:51 PM
John Brown's Avatar
Uhhh ...never saw a Camaro/Nova subframe that looked like that diagrahm Looks more like a Corvette.
John Brown
Old 09-09-2005, 09:02 PM
John, Never noticed that it shows a full solid frame and was labeled for Camaro and Chevy II. This one shows the Front Sub Frame but it says its for the Corvettes, go figure!!!
