Old 08-20-2005, 08:12 PM
Default ZL-1 & L-88 head design clarification
Hello,
I am doing some research into building an L-88 engine for
a project. I know the L-88 in 1967 used a different head,
but I'm not sure what it was. I'm trying to determine
which heads were used in the 3 year L-88 program, which
heads were used in the ZL-1 program, and how the cross-over
between the L-88 & ZL-1 programs worked ( if at all ).
I've been told the L-88 ( 68 through mid-1969 ) may have
used the '842 closed chambered heads. Sometime in mid-
1969, the ZL-1 came into being as did the '074 open
chambered heads. Is this where the cross-over happened?
Here are some questions:
1) Were all L-88's equipped with aluminum heads?
2) The ZL-1 was open chambered, but when did the L-88 go
that same direction? Was it also mid-1969?
3) Where does the whole LS-6 program fit into all of this?
4) Does anyone have an example of a closed chambered L-88
piston, open chambered L-88 piston, ZL-1 piston that they
can post pictures of?
I thought this would have been easy to figure-out.
Steve
Attachments - The Supercar Registry 154665-head1.jpg 154663-head2.JPG 154545-halfmoon.JPG 154544-L88.jpg
Old 08-20-2005, 09:42 PM
Enoch Enoch is offline
Banned
Default Re: ZL-1 & L-88 head design clarification
The L-88's all were aluminum heads from the factory. The 69 switch over from the 842 closed chamber design to the 074 open chamber design was around serial # 21,000 (if my memory serves me well) But as a side not the L-89's did not change to the 074 they were all 842. Hope this helps, Rich.
Old 08-20-2005, 11:01 PM
The L-88's all were aluminum heads from the factory. The 69 switch over from the 842 closed chamber design to the 074 open chamber design was around serial # 21,000 (if my memory serves me well) But as a side note the L-89's did not change to the 074 they were all 842. Hope this helps, Rich.
Rich,
The L/89's refers to 67-69 - correct? Would an L/89 454 in
1970 have the '842 heads?
Steve
Old 08-20-2005, 09:47 PM
Banned
Also the L-S6 for the Corvette was the 454 version of the L-89 but they had aluminum open chamber design heads.
Old 08-20-2005, 10:42 PM
ANDY M's Avatar
ANDY M ANDY M is offline
The L88 head was also made in steel as a parts replacement item.
If you went to the parts counter at a Chevy dealer and ordered an L88 long block, it would come with the steel heads. I have a CE stamped 512 block, and on the inside of the head is stamped L88.
The casting # for these heads is not listed in all of the Chevy parts books, like Colvin's.
COPO 9561/9737 M40 X11D80
13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22
Old 08-20-2005, 11:04 PM
Andy,
What was the casting number for the steel L-88 heads? I've
never heard this before. Love to know more. Also, what
made them different from any other rectangular port big
block head of that same production period?
Steve
Old 08-21-2005, 01:12 AM
Banned
The L-89 in '70 was only for the 396. The L-S7 that never made production would have had the open chamber aluminum heads. (Which over the counter could have steel heads also.) The L-S7 was to replace the L-88.
P.S. The L-89 in 70 was closed chamber.
Old 08-21-2005, 04:02 AM
ANDY M's Avatar
Steve, I wish I had taken photos of the casting numbers when the covers were off. The "HI PERF" is there, and the dates are March and April of '69.
They also have the "half moon" casting mark, indicating a closed chamber, square port application.
Difference between them is the amount of grin on your face at WOT.
Old 08-21-2005, 07:09 PM
Rich, I believe the last LS-6 Corvettes produced in -71 got the first open chamber iron heads, similar to the #074 aluminum head.
Anders Stålklint.
Old 08-21-2005, 08:36 PM
ANDY M's Avatar
All Chevy casting marks are on the front face of the head.
