Old 08-19-2005, 04:39 AM
KnoxvillePig KnoxvillePig is offline
Default Removing oil stains from Exhaust.
Can anybody elaborate on the best method to remove oil stains from stainless steel exhaust tubes? I have heard that oven cleaner and a scotch brite pad does the trick.
Darrell
1969 Camaro RS/SS L-78
Old 08-19-2005, 05:31 AM
Don_Lightfoot's Avatar
Default Re: Removing oil stains from Exhaust.
When needed on my stainless system Darrell I use SOS pads and a lot of elbow grease. My system is not polished. A different approach may be required for a polished system.
I will also follow this thread for other alternatives.
Specialized Chevrolet Decals
Old 08-19-2005, 06:10 AM
Thank you Don. I love The Blue Beast (just checked it out).
Anyone else have any recommendations or ever use oven cleaner?
Darrell
Old 08-19-2005, 08:03 AM
camarojoe's Avatar
for polished systems, just use finer grade steel wool, either 00 or 000, but it will require even more elbow grease... i wouldn't use oven cleaner, as it's likely to etch the stainless, giving you a new problem all together. Another recommendation is to then fix the oil leak thats causing the staining in the first place.
Joe Barr
Old 08-19-2005, 09:18 AM
Thanks Joe, I'll probably stay away from the oven cleaner and just use extra elbow grease.
The oil leak was from a valve cover gasket that had apparently dry rotted. The car sat in storage for quite a while and was rarely driven by the gentleman I bought it from.
Unfortunately, some oil had already leaked down to one of the exhaust pipes before I realized the problem. However, I strongly suspect there will be no more problems w/ leaky valve cover gaskets considering the motor was pulled from the car shortly after.
Thanks again
Darrell
Old 08-19-2005, 09:43 PM
Plowman's Avatar
Plowman Plowman is offline
While working in a welding shop, welding stainless steel you sometimes get stains. We used lemon juice on a shop rag and it took it right out! Try a spot and see how it works.
