Old 08-17-2005, 02:08 AM
Tim Penton Tim Penton is offline
Default NGK plugs
Tom, Rob, & SYC memebers, Which NGK would you recommend for a fairly stock (I did not build this motor) 325 hp 1968 396. The motor does have a Holley instead of a Q-jet and it also has headers. The motor has a small lope at idle. Thanks, Tim E. Penton, Jr.
Old 08-17-2005, 02:34 AM
Chevy454 Chevy454 is offline
Default Re: NGK plugs
Would it use the same spark plug (physical dimension-wise) as an 840 head? If so, try an R5671-7...
