Old 08-11-2005, 07:16 AM
hep1966 hep1966 is offline
Default 65/66 Big Block Carb ID Help
FYI, the same post is on chevytalk.
I've been offered some 65/66 parts but I need some help to make sure they are correct.
The first carb is stated as being for a 66/425 Corvette. The following codes are on the carb, either stamped or cast.
3886101
LIST - 3247
5B1
6R 2829 B
P10
The second carb is stated as being for a 65 396 Corvette.
LIST - 4781
0153
7049
4781
6R 3738 B
P-32
2A
There is a mark of "549D" that appears to be stenciled or inked on the carb.
He also has a GM grill for a 66, still in the box but the box has been opened. A used shifter and linkage is available too.
I'm hoping that the carbs are correct and I'll be looking for a way to ID the carbs but thought it might be faster to post here.
Thanks for any help that you can provide.
<span style="font-weight: bold">John
Chevelle and Tri Five Parts
56 210
66 Chevelle
</span>
Old 08-11-2005, 07:35 AM
John Brown's Avatar
Default Re: 65/66 Big Block Carb ID Help
The 3247 is a 66 427/425 Corvette. Built December 1965, 1st week.
The 4871 is a 850 cfm double pump aftermarket carb.
John Brown
Old 08-11-2005, 07:44 AM
Thanks.
Is this info available online? I've been searching but cannot find a good source.
56 210
66 Chevelle
</span>
